Anyone know of an authority that might be able to answer questions that the parts list doesn't on this bike. Mine being an early VIN has several parts that were changed mid production with some reflected in the on-line fiche or first parts manual and some not mentioned. For instance the front wheel, tire and fender change from 19" to 18" and the gauge mounting studs location from below the cable lug center line to in line with the cable lug. It might be an impossible task to find which frame number the changes occurred with but I intend to try. The front fender size change is indicated in the parts fiche (61100-294-670XW (19") to VIN #1010956 and 61100-294-671XW (18") from Frame SN 1010957) but the gauge mounting studs isn't so I am on the hunt. The gauges on mine have the lower mounts and the bracket is of a different design than the one in the parts fiche. Below are three parts from the "SPEEDOMETER + TACHOMETER" parts page with the earliest part number listed in the parts list followed by the later parts fiche number.
SPEEDOMETER ASSEMBLY
Early: 37230-292-671 Later: 37230-292-672
TACHOMETER ASSEMBLY
Early: 37240-292-018 Later: 37240-292-028
SPEEDOMETER SETTING PLATE
Early: 37211-292-000B Later: 37211-292-010B
If this stuff seems inconsequential to the casual restorer keep in mind that some day when this bike is sold a nit picker like me will appreciate the trouble I am going through and the bike will have a bit higher value also.
TACHOMETER ASSEMBLY
