Maineiac
Ultimate Early Style CB750 Frontend
New Cycle-X early style forks
New fork caps
T-Kat fork brace w/satin powder
New fork seals & gaiters
Slightly polished fork lowers
Progressive fork springs
Dual disks lightened &drilled
New Tracker style master cylinder
New stainless lines & alloy tubing
New stainless caliper pistons & seals
New EBC brake pads
New bleed valves & caps
Calipers powdered satin
Cycle-X billet triple trees
Excel front 1.85"x19" alloy rim
New tube & rim strip
New wheel bearings
Powdered satin spokes
Avon Roadrider tire 3.25x19
Slightly polished hub
$1,200 Firm, plus shipping. Located in Portland, ME. Not willing to separate (you can sell off what you don't want). If it doesn't sell, it goes on the CB450.
The whole frontend has approximately 1,200 miles on it. I used it with an all balls tapered bearing kit.
Notes: Spokes are powdered black, there are some chips. Powdered calipers have some chips. Triple trees are drilled and tapped for gauges and headlight. Right side caliper has a bent hard line. Right fork has small scrape which could be polished out easily. Never got the right side caliper perfect with its alignment to the rotor... I had slight pulsing.
Contact: sethdhawkins(at)gmaildotcom.
New fork caps
New EBC brake pads
New wheel bearings
