Easy CB360 Question- Exhaust Collars
Jojah17
Active Member
Hey guys, new here and just had a quick question- Im at work so I cant pull out my manual or my Clymers. Does anybody know the size of the stud thats on the exhaust collar on a CB360? Im looking to take my exhaust off this weekend for some wire wheel/paint action. I've got the painting part down...but any extra advice on popping the exhaust off/putting it back on? Total newbie. Thanks!
Not sure what youre asking. If you are just taking your exhaust off, all you need to do is remove the 4 nuts that hold the two collars on and slide everything off. Dont remove the studs. They stay put in the motor.
Putting it back on is easy as well. Just repeat what you did to remove them in the opposite sequence...
Sorry, Im lacking in both coffee and sleep this morning...I was speaking about the 4 bolts that hold the collar on. Im not sure what you call them...socket screws/allen heads? For reinstalling I was just making sure I didn't need anti-seize or something like that. Thanks!
Nope, no anti seize. Should be a 12MM bolt. Might want to hit it with a little PB Blaster or the like first.
Aha! Now I see why my question was so crazy- I just took a quick glance at the bike when i left for work and only looked at one of the collars! 3 of my collar attachments use the stud/ nut arrangement and one uses a crazy allen head bolt that goes through the collar and straight into the head. Im assuming one of the PO's broke/lost a stud and replaced it with this bolt. First question, is there anything wrong with this arrangement? Should I look into getting a replacement stud? Secondly, if I still want to take off the exhaust tomorrow- is this a bad idea? The bike runs fine as is and I really dont want to have a broken bolt stuck in my head. Any suggestions on getting that bad boy out? Thanks guys!
You should replaace that bolt with a proper stud. I think you can find sets on ebay still, for little money. When you take the exhaust off, make sure you dont lose or damage the inner collars. And you should replace your exhaust gaskets as well. new ones are only $5 or so. Thats also an insanely simple job.
Thanks for all the help! I just placed an order for some gaskets but am having no luck finding the studs. Any clue where I might pick some up?
You just need to know what thread and pitch they are (sorry cant remember off hand) and length. Any fastener store will have them. Get stainless if ya can.
The snowpacalypse of Atlanta has finally decided to end so I can finally make my run to the Hardware store and grab what I need. Hopefully my gaskets make it here today as well. So 8x1.25mm stainless steel studs are what I need to look for? Thanks again for all the help guys!
Wanted to update in case anyone had a similar question. Found the stud at a local fastener store. Size was 50 mm long 1.25 mm pitch and M8 thread. Slapped some anti-seize on and was good to go. Thanks guys.
