Swagger said:
I've been glancing at your write-up on and off and I'm really glad someone did this!
I've got a couple pair of them here in the shop and I'll have to dig in.
I'm not all that surprised that the double clevis thing resulted in a break, bad design on their part, however the shocks themselves don't seem all that bad. Not Ohlins......but certainly not bad and when you factor in the initial cost they pretty acceptable, You get a shock that's (again, perhaps not on a level with Ohlins or Works but...) worlds better than anything OEM on our old bikes.
I like your new clevis, they should have been that way from the beginning.
A note on a couple of your pics: on caferacer.net (yeah those guys) Hack who's obviously itching to jump on anything noted that the shock shaft looks bent. I'd wager than you're seeing lens distortion. I take a fair amount of pics of my work and run into that fairly often. If you take your pic with the shock more angled across the screen it'll help hide that artifact. of aim slightly high and recrop in photoshop. On my 10 year old digital I can see the lens distortion while looking at the teeny tiny screen and can compensate on the spot....you should look into that.
Back to the shocks for a moment. Have you dug into the reservoir yet?It would be interesting to see what's going on in there.
It occurs that something like a Gold Valve could be dropped in to make some real improvements on damping action both high and low speed.
As well with regard to your initial dissatisfaction with them bottoming out; it's not a matter of spring rate but of poor damping.
I'm sure you've addressed it but I didn't see it anywhere.......think about 'tuning' with heavier oil. Any fork oil will do in this case...again I'm sure you've thought on the subject.
I don't know about better than "anything" that came on these bikes stock lol. I have some pretty slick 3-way adjustable Showas that came on my '81 GS750, but they do leak. This is all aside the point, though.
First, as far as Hack goes, I had decided to just ignore his posts until today. He made a couple that were not entirely snide and condescending. It's not his project...it's amongst myself and a few others...thus his input is ultimately irrelevant. The actual substance of his banter much appreciated, but ultimately irrelevant.
As far as the pic is concerned...there is lens distortion and the pic was a far right crop, but the lower spring plate is poorly machined and does add an odd angle to the equation. The spring base plate is a 2-pc assembly. The inner piece is what connects the lower mount to the piston shaft. This piece, on the outside, is cut very nicely. On the inside, though, not so much. The threads are poorly cut, especially on the lower mount side, and this allows for the stock assemblies to "wobble" some. Putting my new, perfectly cut threads into these poorly cut threads resulted in one of the shocks being a bit "off". I pull-tested the assemblies to 500lbs each...I figure if it'll hold 500lbs it'll be okay to run for a while. Soon, I will cut another piece to match my new lower mounts. I'm working on finding a price for having new lowers made for people who've already bought the shocks, but anything else will be machined to replace both the lower mounts and the inner spring base as a single unit.
I have not been into the reservoir as of yet. It'll require the use of a press that I do not have ready access to. It's made much like the type of forks that use retaining clips and plugs instead of screw caps.
Though I didn't try riding with the low weight oil, I feel that the bottoming out was more to do with the lack of travel. These shocks have a GIANT bump stop that takes nearly an inch of travel away. After removing the bump stop and adding 20wt oil, I'm using around half of my available travel during normal riding and am still not bottoming out on hard dips. I haven't posted my ride report yet, but at the top of the website there is a link to refilling the shocks.
