Re: Suzuki Savage LS650 Scrambled Egg
Ended up going for the GT185 tank. It has a few advantages:
- the Suzuki Savage petcock is an exact swap.
- said petcock fits without modification as it clears any obstacles on the left side and sits between engine and choke lever pretty much perfectly.
It also takes the LS650 front tank rubbers.
Also I wanted to be able to have passengers and therefore wanted a smaller tank length wise so we have little more arse room.
Yep the GT185 capacity isn't great but is actually a shade larger than the Ryca tank so I'm sure it will do as a round town bar hopper.
Following in others footsteps with slight variations, used the old tank mounting points and the old seat mount to create a holder for the GT tank hook. Works great:
mid section just needed at bit of mouse mat to cushion the contact point:
welded a nut on each side at the front:
bit of threaded rod with a penny washer welded on to give the rubbers a bit more to hang on:
