Anyone here running BCR's El Poquito exhaust? It's the high mount 2 into 1 setup. I started to dry fit mine together and I'm not sure how it connects to the engine. The stock exhaust is long gone, but each pipe used a 2 piece sleeve that wrapped around the original pipes and was held in by a ring that bolted on. I'm assuming it's a pretty standard setup.
The El Poquito exhaust has a flanged end that is too small to be held in by the ring piece. It slides right through. The new exhaust has a slightly larger flanged piece that is about 2 inches long and slides right over the exhaust pipe that attaches to the head.
The first picture shows the pieces I've got. The second picture shows how I think everything is supposed to fit together, with the pieces in my hand sliding inside the exhaust port on the head. Only problem with this is that once bolted up, the larger flanged piece is pretty secure, while the main exhaust pipe isn't held securely at all. It still has room to twist and turn all over the place.
I'm not sure if I'm missing pieces or maybe I'm not supposed to be using the original 2 piece sleeve that I'm holding in the second pic. Anybody install one of these or have any ideas?
