Electric relay questions...
Redbird
Dolor est Magister Optimus
DTT BOTM WINNER
Ok, I have enough electrical knowledge to know what I need... but not what to look for, or where to look.
I need a 4pin (or maybe a 3pin) normally closed relay for use with LED's in an automotive application.
I doubt the auto parts chain stores will give me anything more than a stupid look if I walk in and tell them that. So, what/where do I look/go?
Just for reference, this is for my Stepside. Years ago I converted all the exterior lighting to LED's. At that time I custom fitted a single intensity LED fixture into the front sidemarkers. Due to this, I could only wire it one way... either as a running light, or as a turnsignal. I want to correct that with the relay by having the running light on, but cutting the power when the turnsignal circuit is on. Thus making it "flash" by going off with the turnsignal pulse, instead of getting brighter.
Make sense?
Oooooh I got ya now.
You need a relay that turns off when the power from the tirnsignal stalk hits it.
Hmmm I'm not sure what that's called. I'll look into it.
Looks like you need a "single pole double throw relay"
If it's only for the LED, 5 pin relay
You could probably pull one from an old tape recorder (only need a tiny one, less than 1 amp)
just wire it so normally on and switches off when power is applied, in effect wired 'backwards
Well, after racking my brain trying to figure out how to wire it, I remembered why I didn't wire it that way the first time... I'd have no turnsignal when the running lights are off *forehead slap*
