Electrical Charging Issue, with test results inside
TurdFurguson
Weird Indy Kid
DTT BOTM WINNER
The last issue im having with the 100 seems to be with the charging system. I have gone through the FAQ at http://oregonmotorcycleparts.com/FAQ.html to try to pinpoint the issue, however his tests check out. I have finding that arnt explained in his faq, and I dont have the knowledge yet (trying to figure it out) to know if they are concerns.
Im getting about 4.5v out of the system, and it doesn't change with the headlight. This is being used with a CB350 stator on my CB100.
I have gone through Faq3 and the rectifier does test out ok according to what he suggests, however, I am also getting one way continuity from the ground to positive and both AC terminals. It is backwards of the positive continuity. So, with the common from my multimeter on the positive terminal I have continuity to both AC terminals and VERY poor to the ground. With the positive from my multimeter on the ground terminal of the rectifier, I have the same readings from each AC terminal. This seems odd but maybe is expected.
I then checked the stator itself. Again, the tests in fag4 check out as he describes them. I get about 1 ohm from the pink to yellow and about half an ohm from pink to white. However, I am also getting continuity from yellow to white, and since they should be creating continuity at the headlight switch, this seems wrong to me (but again, im still trying to learn the charging system). The switch itself does work and creates continuity correctly.
So, im looking with someone that knows more about how these should read out to help me pinpoint where the issue is.
