Electrical Help
Pmbjngls22
I am terrible with electrical stuff, so any help you guys can provide would be great.
I have a 1973 Honda CL350
Two Questions:
Is there anyway of rigging up the front break to turn the rear break light on if the lever doesn't have a switch.
Second, and more important question, alll of my blinkers are lit and don't blink. I replaced all my controls with after market stuff, and I'm not really sure what to hook to the blinker relay (grey wire). The only wires that come out of the new controls are a left blinker, right blinker, and blinker+ . Any ideas on how to get things blinking?
Grey wire should go to blinker+ and then left blinker to (you guessed it) your left blinker(+) etc
And as far as brake switch you can fit a micro switch in there but its a pita, easy way is to find a later model control that has the switch built in.
Even easier way is to always use both brakes :D
I have hooked the blinker+ to the grey wire, but they all still stay on. Is this because the engine is not running?
the question is is it electronic?
Was it 6 bucks or 14 is the simpler question haha.
Then hellifino.
Hook an incandescent bulb in place of one of the LED's and report back whether it flashes or not.
I have gotten a bad electronic flasher from auto zone before...
Electronic relays are made for LEDs
The package should say "electronic" on is somewhere as it runs off a small electronic switch rather than a resistance switch.
Got another question. After hooking up my new controls/switches I had a yellow and a yellow/white wire leftover (coming from the bike not the controls). Judging from the wiring diagram it looks like I can just connect these two wires together. Am I reading that wrong. They seem to go to the alt and the rectifier...
