Electrical problem
vintageyamie
Active Member
I just installed cafe bars on my yamaha 250 and just noticed that i lost all blinkers, kill switch, and horn. The only thing i didnt hook back up was the front blinkers as they are still unhooked and wires are just left in the headlight housing. Is that the reason or is there something else i should be hunting for to fix this problem? And my brake light is on all the time without pushing the brake.
Sounds like multiple problems to me. The loss of multiple switches points to a ground not being hooked up, but the kill switch is on a live (positive) connection. Your brake light switch probably just needs adjusted (don't know how it's done on a KZ though).
Personally, I would disconnect all the connections and start over.
thanks it was a easy fix tho... it was just the grounds on the switches theirselves. the bars were painted black new so the switches werent getting a ground. thanks for your advice
well i thought it was all fixed except i have no blinkers still. i got everything else working but those, any suggestions? maybe the flasher itself? is there any way to check it and see if its good?
you can bypass or jumper it and see if the lights stay on all the time......did they work before you did the bars? possibly unhooked the power (hot wire for the t/s switch) if no t/sig lights at all ...joe
I guess you cant just unhook the front blinkers without rewiring them as the front blinker wires are a ground for the rear. got em fixed
