GLENNWOOD55CAMEO
I have a 1971 Honda CB450. It is not charging to the battery. I have checked everything from the stator to the battery. Everything looks good by the numbers. I have 60+ AC volts at rev coming from the stator. I have installed a new Kolher rec/reg unit. I have replaced the battery twice. Here is my theory. Although I am reading 60+ AC volts at the stator, I believe the AC voltage is breaking down under load. To test my theory, I removed the two AC wires coming from the stator at the reg/rec unit. So I am now reading 60+V AC between these two wires at 4000 rpm's. I then connected a 12V DC taillight to these two wires. I cranked the bike and the light lit slightely. I slowly reved the bike to 4000 rpm and the light increased in brightness to the point of being super bright but did not blow out. My question is, Is a 12V DC taillight bulb capable of withstanding 60V AC with out blowing out? If the answer is no, then That is my problem, the 60+V AC is breaking down under load.......................
