electricity = confusing
johnny gaijin
so i'm trying to get my tail light to work on my '75 cl360.
stop light works. head light works. turn signals work. tail light does not.
my multi-meter tells me i'm getting 10 volts on the wire that plugs into the light and i'm certain the light works because if i run a wire directly from the battery to the light it works.
so i scratch my head for a couple hours and then accidentally turn the key all the way to park or whatever it is (who uses that? why is it there? retarded?) and bam my tail light comes on.
what's going on?
The third position on the key switch is a "park" position. It's for if you have to park the bike on the side of the road at night and you want to leave the tail light on so cars don't hit you. It should only turn the tail light on.
As for why it doesn't come on, it's hard to say. Clean the connector really well and try again. If you measure voltage at the end of the wire, but it isn't getting to the light, there is a disconnect inbetween. Your ground is working, evidenced by your other tests. Check continuity between the connector that your plugging into and the positive "pad" in the bulb socket.
Sounds like the pin for the lights in the ignition switch is not connecting when it's turned on (but does so when in park).
Take the back off the ignition switch and check / clean the contacts.
i checked the wires behind the ignition... everything looked good. put it back together and voila tail light works. we'll see if it sticks. thanks for the help.
