elephant ass reduction
rockcitycafe
I make things.
how to you turn an elephant's ass into an actual race-able motor? CHOP SHIT OFF!!!
I'm using a cb400 alternator from the junk bin, and will be running chain and sprocket with a tensioner from the crank to the new alternator, takes about 3" off the side of the engine, will be doing similar to the points cover too, will make the fairing a lot more slim since I won't have to cut holes for both the covers anymore
Wow - that's pretty tidy....and a bit clever ;)
I remember seeing a Katana once that had the stator removed / blanked off and the guy ran a small car alternator off the drive chain (on top of swingarm between pivot and tyre). Obviously it only charged when the bike was moving, but it was very tidy as well.
wouldnt that alternator pretty much explode at high speed?
looks SICK by the way... cant wait to see this bike done =D
Pretty much not ::)
Think about it - does the wheel spin faster than the crank? Only in top gear....maybe....depending on the bike.
Yeah that alternator should be fine. I like the idea. I have thought about doing something like that to my bike to gain some clearance in the corners. I would like to some more pics of that setup. I would also like to see it when its done.
Great idea - is there a smaller alternator out there to do the job?
If your going for race-able... Why not got with a total lose system? Now you've saved width and weight...
I looked at that when I saw some of the really small batteries available, but having this bike as track only would make me sad... I also had this cool idea a while back and will be taking it out of the icebox for this one, I'm pulling the stator coil and fabricating my own permanent rare earth rotor for it, I had doubts on the idea earlier as the rotor would be inside the engine case and the rare earth magnets are sensitive to temperature, but since the alternator won't get as hot now, it should work
