ElHatton's rookie '75 CB360 cafe build
ElHatton
Hey guys, long time lurker first time poster! Glad to finally be on the board and be a part of the crew here. I'm a huge noob to doing hardcore chopping and engine work, etc. but I've been through a lot of the build threads here and since I have something to work with I'm pretty happy to get started on my own cafe bike. Plus you folks seem to be nice enough with helping people out I figured there wasn't TOO much to be scared about. ANYWAYS, here is the 360 I picked up today. I probably won't have a lot of time this weekend to really tear into it but I can hopefully get started on some minor things.
The battery is dead, but the engine was great considering the bike sat over the winter and its' previous owner was 16. Everything starts but the carbs need some work. Thought about taking it in but if you guys know how to/I find a thread about doing that stuff I might give it a shot. I'm a big fan of kruksters 360 as something to start off with and Motofiaccone has a gorgeous one with a ridiculous pipe on it, so I have a ton of ideas to go off... and then hopefully go to a custom painted tank, framework and etc. Don't want to start plagiarizing though so I need to figure out a theme to work with.
Will update with pictures as I go along, as usual. Thanks for dropping in!
Nice bike. so you need to clean your carbs? Get you a manual. That will get you started in the right direction. Get the carbs off and just be patient and make sure to get all the little passages I use compressed air if the air goes in it must come out from another spot in the carb.
Beauty, thanks Thompson, will do. Looking forward to your GPZ by the way. :)
Welcome to the site man! Looks like a really good bike to start with. Don't hesitate at all to ask all sorts of questions - there's always an answer.
+1 to Thompson on getting a manual, it's a necessity. And when you do start pulling the carbs apart, make sure you do it with a very clean work space! Last thing you want to do is drop a tiny part and have it get out of sight!
One last thing - don't worry about plagiarism. That's why everybody posts their work, to share ideas!
the thing with carbs is to be meticulous. take your time, make a space for each carb, lay it all out, use small trays to keep stuff organized. write down the settings in turns (ie. 2 1/8 turns open) for each air bleed or mixture screw. take the bowls off first and see what things look like. unscrew the jets, blow them out with B-12 or whatever kind of carb cleaner you use. spray all the air passages, parts and pieces. Using carb spray then chasing with compressed air works great. when you take out stuff like the low speed mixture screws (that often have springs/ washers, o-rings, etc) make sure to lay them out in the order and facing they came out. or just look at an exploded view (check bike bandit.com for example). Other things you can check/test while you are in there are the float height which can give problems if not set correctly, and also the float needle valve and seat, which are prone to wearing and leaking. You can test if it is seating/leaking by using a piece of fuel tubing and blowing down the fuel inlet tube for example.
lots of step-by-step guides are online, and forums for almost all types of bikes. I'll bet you could google it and come up with an illustrated how-to for those specific carbs. then just spend 2-3 hours and have a couple cold ones and they will be good as new. only basic tools needed.
are they slide carbs or CV carbs??
hey, what are you saying about 16 year olds anyway ;) ;)
looks like a good base... welcome to dtt- keep us posted
Haha Rocan I have been more than impressed with what you've been doing so far with your bike. The guy I got it off was kind of a goof and was selling it because he was getting a car and didn't need a bike with his full license. Obviously didn't have the vision guys like us have haha.
fastcat14 said:
the thing with carbs is to be meticulous. take your time, make a space for each carb, lay it all out, use small trays to keep stuff organized. write down the settings in turns (ie. 2 1/8 turns open) for each air bleed or mixture screw. take the bowls off first and see what things look like. unscrew the jets, blow them out with B-12 or whatever kind of carb cleaner you use. spray all the air passages, parts and pieces. Using carb spray then chasing with compressed air works great. other things you can check/test are the float height which can give problems if not set correctly, and also the float needle valve and seat, which are prone to wearing and leaking.
Yeah... fastcat half of that was gibberish to me so I have a lot of reading to get to! I might just get my girlfriend's dad to do it, he was a Honda mechanic in the 70's. I may give it a shot down the road/next bike I work with. :) Though anywhere I can save money to spend on other things like a seatpan or lights is always good.
I highly recommend AGAINST having him do it for you. Having him there next to you as you do it would be pretty much ideal though. Just because eventually you'll have to do it yourself or you might be out somewhere and run into a little problem with the carbs. Just my 2 cents.
Besides - carbs just look intimidating at first!
Fair enough, man, fair enough. Then that just gives me an excuse to make a video and come back here for you guys to walk me through it, eh? ;D I'm visual/kinesthetic, gotta see it and do it to really grasp the idea of something and how to work with it.
Seriously man... Carbs arent a big deal. They just look like it. Once you pick up a manual and do a little research online and grasp how they work it will all make sense. These older bikes are about as simple as it gets mechanically. Like BigR said, having help is awesome but do absolutly everything that you can yourself. These bikes can be VERY relaible, but you always have to remember that they are 40 years old. Things break, or go out of adjustment, and when your 100 miles away from home, YOU need to be able to keep her running. When (and it will) something goes wrong, having had your hands on it or seen how it works firsthand will save you a huge amount of time and trouble. The guys and gals on this site are not only extremely knowledgable, but also some of the most helpful around. Theres nothing you can run into that someone here wont be willing to help you with, because they have been there at some point. It may sound kinda silly, but when you take on the responsibility of turning a vintage bike into something personal and cool, you have to form a bit of a bond with the machine. Even the remarkably well made and designed Hondas can screw ya if you dont know everything you can about them. Love your bike, and I mean ALL OF IT, and it will love you. Now order a manual (a real Honda shop book, not a cheap one) and get to work! You'll be just fine man.
Holy christ, I started taking on the task of simply removing the bars to find the wiring running through them. Gonna be a little bit more work than I thought and not nearly as easy as my Ninja. Nothing is ever easy eh? Anyone have any tips apart from labeling everything while pulling it all out?
Funny you ask - but are you just removing the bars to put them back on later or replacing them with new ones?
Well it depends on how well the bars I'm gonna use fit/feel haha. I have my Ninja's old bars that I was going to throw on there. I was going to just see how it looked when I discovered the joys of the internal wiring.
All the wires are colour coded, so if you have a manual with a wiring diagram it's pretty hard to go wrong.
If you're planning to run clip-ons or clubmans I would notch the switch blocks and run the wires outside the bars. You can use heatshrink to tidy up your wiring and cable tie them to the bars to make it all neat.
Alright sorry guys it's been a while, nothing truly fancy so far but I got the tank and carbs off. Going to strip the tank and rebuild the carbs sometime later this month once cash comes in again. :P
Been fun to work on though, nothing is super intense so far except for the wiring in the bars freaking me out from continuing on getting them off till I get a real shop manual.
From what I've seen 360's can be turned into a pretty cool ride. Don't let the wiring scare you, these are old girls with just the basics to get along.
Incase you don't want to wait for the manual:
Remember green is ground and black is hot. I cannot stress how important a good ground is. Knowing that and chasing through this diagram should help you get cracking.
http://www.oregonmotorcycleparts.com/Diagrams/CB-CL360.jpg
