Engine 2 tone paint... help...
joevirus563
Coast to Coast
Hi again DTT Community.
Once again I need your help.
I want to paint my head and cylinder in black but the cylinder wings in silver, but the tips of it.
So 1 step is silver paint... but how can I hide the wings so I can apply the black?!?
Tried tapes but its a little small to stick to the tips of the wings... any product I could put with my finger to prevent the black paint to stick to it?
THANKS!
You actually have 2 options that I know of. 1) paint the entire motor black and use a small sponge / brush to paint the tips of the fins silver. 2) paint the motor black and get some wet sand paper to remove the paint from the fins after it's cured
Ok Option 2 wont remove the silver underneat?
True... I dont really need to apply a silver base coat since my engine is aluminium... just need to sand it and maybe put a little clear over to make it shine a little more???
Yep, this is what rich was saying....After the black has fully cured, use some sand paper on a sanding block and sand the fin tips back to the aluminum, once you get back to the aluminum, just wet sand with several different grits working your way down to a 1300 or 1500 grit paper, that will give you a nice shine on the material. Then just a nice coat of high temp clear to protect it and you are good to go!
Oh, and try sanding in only one direction the whole time, it will wind up with a better finish that way!
YOu guys really save my life... I was about to kill my self (Not really)... I tried many time to achive the wanted finish without success... didn't tought about the sanding thing at all!!!
THANKS! Will give it a try... but now I'll have to remove all the paint from the head an try everything again....
Just remember - the black HAS to cure before sanding the fins. Or else it will flake away while sanding or leave water marks
Ok here's another tought... can I paint silver cure, and paint black and try to wipe with something?
I would not try this, you will not be please with the finish!! Not even worth it when the aluminum will look way better than paint anyway.
To remove paint, use aircraft stripper! Be carefull using anything else on aluminum.
Thats what I use... but its in gel... kind of hard to spread it :)... would prefer a spray :D
dean owens said:
go to walmart. they have the stripper in a spray can.
Yeah I know one already :) I used both Aicraft striper and spray stripper and found the spray as effective as the aircraft but can reach easier.
you cant do polished edges on your cylinders.
your just not allowed to. its too cool and that is strictly reserved to my project on DTT.
:D
