engine/alternator skip a beat
modest
1977 cb 750f/ 71 engine
Either my engine when im sitting at a light or my alternator sometimes skips a beat is that something to worry about, and not all the time does this happen ......much thanks
What do you mean by "skips a beat"? Does your headlight and motor die for a split second and comes right back on? If so, sounds like a bad ground possibly near your reg/rect
No just like if your heart was beating really fast and then just skipped a beat real quick and then went right back to normal if that makes any sense
Kinda tricky to diagnose. What kind of bike is it? I would guess if it's missing on the ignition at idle it might be a carb problem.
Then again, could be lots of things. Is the engine warm/cold/doesnt matter?
1977 cb 750 f with a 71 engine and i guess mostly when really warm but like i said doenst always happen.
idle is never really 100 percent conisistent on any bike... shouldnt be anything to worry about unless if it happens at all rpms.
Idle should be dead regular on CB750. check all the wiring connectors, battery terminals and the ign. switch.
It sound like an electrical fault where your loosing all power or, the advancer unit is sticking so timing is ay over advanced at idle (possibly broken spring on advance unit?) take a look under points cover (round chrome thing on front right side of engine)
PJ
