for an air cooled motor get yourself a gun cleaning kit, a multipack of cheap toothbrushes, a couple bigger brushes, a garden hose, lots of WD-40 and lots of carb cleaner.
Oh, well then you need oven cleaner, files, sandpaper, polishng papers, buffing wheels, an angle grinder with a good selection of small mops, tripoli, rouge, and this months issue of of Classic Motorcycle mechanics.
As long as nothing harder than aluminum touches it, you can use it. Try paint brush handles wrapped w/ wet dry paper, bondo applicators wrapped with wet dry, etc.
Personally I'd skip polishing the engine and soda-blast the entire thing. No paint. Cools better. Gets dirty easy but it's easier to maintain (i.e. no work). All BMW airhead engines are raw aluminum - no paint. That's what I did with my XS650. I did polish the side-cases, but the engine cases, cylinders and head are all just blasted aluminum.
How can it both be easier to maintain and get dirty easier? Polishing is a big PITA but once it's polished it's the easiest thing in the world to keep clean, nothing sticks to it. Raw sandblasted parts suck dirt and grease and even stain if you look at them funny. leaving it sandblasted would be a nightmare (soda blasting is less aggressive so it would be less bad, but still a pain) I don't even handle sandblasted parts with my bare hands because they will fingerprint, and you can never get them clean again.
I think a good compromise would be to soda blast it first to remove any dirt / surface corrosion, then start polishing. Even a "mild" polishing up to 800 grit will give you a really smooth engine.
