Engine...hot? Or stock?
sclay115
Trying to decide what direction I want to go on my CB350 lump. Obviously the options are there for some power, Hi-Comp pistons, hot cam, newer carbs, lots of stuff. And there is the option to just do an OEM rebuild. Here is the deal. My cylinders need to be bored, they have some surface scratches and such, and I say to myself, self, you should just get some Hi-Comps and slap them in there. But of course with that, comes the cam, the carbs, the list goes on.
Or I could just go with an OEM rebuild with a bit of an overbore, WAY cheaper, but also down on power.
I'm thinking I might go with an OEM rebuild, just to save some money so I can spend it elsewhere, paint, good tires etc. How much power could one expect out of a real hot 350? And compared to a stock mill, is it really a huge jump? And with just going OEM, I can use the stock carbs/cam, all that. What do you guys think?
Steve
All depends on budget and application. What are your plans for the bike as a whole? Is it going to look stock? Lots of street/city riding?
You're talking about many hundreds of dollars to go hi-comp, hot cam, ported heads, better carbs etc. etc. If you're going to do all that, you should look at lighter rods, balance the crank etc.
Bottom line is do you need a racing engine that may or may not run well in day to day driving, or do you want something that runs easily in many conditions but with less power? I'm sure there's a happy medium in there somewhere, but I'd spend my money on the rest of the bike.
A hot engine in a not so hot suspension for example won't do you any good.
What I'll probably end up doing, is finishing the rest of the machine, then seeing what state the bike is in to dictate engine choices. I know what you mean about the whole 'if you do one thing, might as well do it all'. And I agree, which is why I'm leaning toward just a stock rebuild, something to get me some good gas mileage and run for hopefully much longer than a strung out 13:1 beast.
Steve
68-69 cam and rockers if you can find them,(more lift and higher redline) 30mm mikunis(motovan)cb 360 carb boots,gpz 750 pistons(66mm),or just skip the carbs and cam,,,and be sure to run premium(shell 91 is good!) the outside of the pistons have to be machined so they don't interfere with the stock head gasket and the head,,,,this mod alone will increase the compression slightly and add 20cc,,,,,,one better is to find kz 440 pistons(67.5mm),,,there hard to find,,,hope this helps
[hi-jack]
I'll go ahead and jump in here... I'm an idiot when it comes to engines. I was going to post about it but since the audience is here...
I'm running a CB450, 1972 engine I believe. It's stock but currently torn down at a friends shop. All I have purchased thus far are 50cc bore pistons and a copper gasket set. Can anyone recomend what else I should/would want to look into? I'm looking for high-power output and hi-revs (I think) not gonna track this bike but will be riding it daily.
I assume a CAM is in order (what kind? and grind?) along with a nice multi angle valve job (suggestions?)...
Any info is greatly appreciated. I'm a ways a way from the engine but at least I can add it to my file and start researching.
Side note, I've read somewhere about 500 heads when using big-bore pistons. Does that sound right?
, Holliday
[/hi-jack]
Oh...and I'm trying to eliminate that "idiot about engines..." I'm up for learning..
Stick with what you have already,avoid cams mods,its a daily driver!!!!Junk the cv carbs,,,,,cause there JUNK,,switch to mikuni's(sudco,sporting for less,winners circle) and then search an exhaust system that won't piss off the neighbours(swarbrick,todd henning,team hansen)then fit a dyna (gold wing version) ignition,,,,,,,,don't build a race motor for the street
