Engine is Clanking
Matt
I have a 78' cb550 w 28,000km...when starting the bike cold it makes a clanking noise. It decreases as the engine warms up or if i raise the idle. The bike runs smooth at 1300 and the power is still there. Im not too mechanically inclined so suggestions would be appreciated.
Don't know much about cb's but when my carbs were badly out of sync on my kz650 it clanked like you're describing, once I bench synced the carbs the problem went away. It could also be a primary chain issue, but I'd start with syncing the carbs.
Could be the cam chain tensioner? You could have your valves checked. Mine had needed some adjustment
recently?
Carbs !!!!!I think you are on the right track I got my Kz650 last fall allways needed lots of choke to start and keep running till Warm,,lots of noize too . This spring i got them sync WOW what a differance one kick on a warm day sweet ;D good luck
thanks for the advice...i'll see what i can do. any advice on where to buy old honda parts such as a carb rebuild kit
Check Z1 Enterprises, www.z1enterprises.com. I've always had great luck finding stuff for my kz, haven't looked for honda parts specifically but I know that Jeff has stuff for all the big vintage jap bikes.
I've found most of what I need for my CB on ebay, but DavidSilverspares.com has good stock as well.
+1 this guy can even get you some new torsion bars which are hard to find.
I have a 78 Cb550 with a similar issue. I'm gonna try and tackle that one this week.
Are you in Toronto? If so, I'd suggest TO Cycle on Lakeshore. The guys there are really great, fast for ordering and the prices are good.
I live in Durham Region. I cleaned the carbs, and now my electric start has gone.
It's not responding at all? Did you short it out? Does it start at all? Not really a big deal, I never use that button anyways.
I can get it going with the kickstart normally on the third go
