ENGINE PAINTING!
ty.man
Active Member
Just spent a few hours trying to strip down the motor and its not working. I started with rattle can aircraft remover and that shits for the birds. it cleans decently but does not strip paint. left it on for over an hour. So i went and got some stuff called zip strip. Says it takes ten minutes, that also sat for an hour and after lots of elbow grease and steel wool it takes some of the paint off. How can i strip down the engine to prep it for re paint without disassembling the whole motor? I cant imagine how im gonna do the jugs and heads with those damn fins. thanks all
There is a stripper that is a gel, silver can don't remember the name. I got it at lowes and it takes paint right off.
That being said you can pair over old paint as long as its scuffed up a bit.
Your best bet is media blasting though.
The aerosol Aircraft Stripper defeats itself because air is what causes it to be less effective. The bigger cans that you have to brush on work 10 times better.
Media blasting is a great idea on the smaller parts of the motor (after it's taken apart). No matter what media you use, and no matter how careful you are, some of it will get inside the motor. Not a big deal when everything is apart and you can scrub it down though.
3M aircraft stripper, buy it at Lowes, Home Depot, etc. It's a gel, you slather it on, wait however long, and wash it off, then hit it with some brake cleaner, then finally some scotch brite and then wipe it with denatured alcohol. Then you're ready for painting.
When you get tired of spending money on strippers (I never get tired of that personally) take the bits to a soda blaster and have them cleaned off.
I had my engine cases etc. soda blasted and am leaving them raw aluminum. I figure paint doesn't make it run better and just peels off ultimately. My engine might end up looking stained or dirty in the end, but it's an engine.
Oh! Look into "vapor blasting". I think there's only a couple places that do it in the US, but it makes aluminum look great.
I am getting my motor vapour blasted, do you have to paint afterwards?
Don't want staining afterwards.
