Engine pops
twinkeel
Hi all. I have a 71 CB350. I've had it for a few months & only ridden it a bit. I noticed a few days ago - there is a small oil leak coming from the right cylinder, near the spark plug. It still runs fine though. I fired it up for a few minutes today to just run it around the block.
Every time I let off the gas, I hear a bunch of little pops coming out of the exhaust. Sounds like tiny backfires. It is kinda chilly out - about 60ish.
Is this something to be worried about? I'll attach an image of the oil leak. Any help there would be appreciated too.
http://imgur.com/BwKoT
Popping in the exhaust is usually a sign of running lean and that's to be expected if the weather is cold and the engine hasn't yet warmed up. Take it some distance (5-10 miles) and see if the problem persists.
Also... oil leaks don't usually occur from the spark plug unless you've got some pretty bad issues. Check the areas around the section where the tach cable connects and also where the rocker box seals up to the head.
Thanks Sonreir,
Upon further inspection it looks like it may be coming from the head gasket, but isolated to the right side.
Hear is an album of a few images. Would it be as simple as replacing said gasket?
http://imgur.com/a/Wu6ng / http://imgur.com/yWgmv
