Engine rebuild "kits"??
Big Splash
So, I plan on a pretty complete overhaul of my engine, pending teardown. Now, I have already bought a carburetor "rebuild kit" to do so on my carb, but when I look into preassembled engine "kits" I haven't had much luck. I realize there is a lot more to it, parts wise, but I was wondering if you guys knew of a good resource that bundles together gaskets/seals and/or rings for the standard replacement stuff within the cylinder head/cam and crank shaft/piston rings/etc. I'm not expecting an all in one deal here, but A la carte is pretty outrageous pricing on HOH, or bikebandits.
It's not automotive, you measure parts and replace whats worn.
Depending on miles and use, it probably won't need anything more than a gasket set and maybe piston rings.
If its had a lot of abuse, a primary chain.
If it's over 50,000miles, new cam chain.
Original design life was 100,000 miles but mine needed work around every 8~10,000 miles (but, it was modified to rev to 13,500rpm)
