This is what I am refering to. It is also referred to as High Velocity porting. Some people even think that the major manufacturers use larger ports than necessary in the early years of an engine design so that they can simply make them smaller in order to increase the H.P. ratings over time, which helps keep a model popular. So Ive heard.xb33bsa said:reverse porting i have never heard that term but i assume that it refers to more or less making a port "smaller" because results form trial and era on the flow bech with clay have deamed it effective method as far as i know it ios somewhat common on 2 stroke transfer ports and also for optimizing flo on 4t's i think it was either fmf or edwin boysen who developed 2t reed valve assemblies with "stuffing blocks" i would call them on the upstream side of the reads.it reduced the volume of the area but you could see just by looking at it compared to stock that it would be a better path for efficiency./it just let the air be perfectly funneled wher as before the air kinda did a dump expand as it hit the reeds ..fmf called it 'ram valve'' i think and it was a complete cage assembly just like the boysen "rad valve" ..when i was racing national endurors i had donny emler send me a set for my kdx200 he gave them to me as a support deal it was very cool and the throttle was cleaner it def did not hurt the power.
Shrinking the intake runner speeds up flow which will increase throttle response and torque, not HP. Still can be a benefit, just a different one.DohcBikes said:This is what I am refering to. It is also referred to as High Velocity porting. Some people even think that the major manufacturers use larger ports than necessary in the early years of an engine design so that they can simply make them smaller in order to increase the H.P. ratings over time, which helps keep a model popular. So Ive heard.
JB Weld can be used to accomplish this effect in other applications.
Sorry for the derailment.
What you said was that the reason they did that was for horsepower. Nominal horsepower is gained. You can do things to add more horsepower vs torque or you can do things to add more torque vs horsepower. You are somewhat right and somewhat wrong. The reason you go with a smaller intake is not to gain horsepower. It is to gain torque and throttle response. Cams are another way to go about this transition. When I build drag engines, I concentrate on torque more because it gets me more red light to red light speed. Yes I gain horsepower, but the cam in my Chevy 350 is there because of torques gains- which also gives me better towing.DohcBikes said:Basic rule of engine theory. You CANNOT make more torque without making more horsepower, and vice versa.
In fact, the way most dynamometers work is to mechanically measure the torque and engine RPM and then use those numbers to calculate a graph of horsepower.
Horsepower can be calculated from torque and the opposite is also true. One does not change without the other. Horsepower is the result of torque and RPM. Its a predictable math equation.
These are facts not opinion. But since twenty of my posts disappeared magically last night, I don't expect the facts to be here long. Sad but true.
indeed!deviant said:Dunning-Kruger in full effect, fellas.
You trying to make me pass out?canyoncarver said:I was just gonna say....everybody take a breath and count to 10....
CaferacerMO said:Alright guys, put the cylinder and head back on and I just got the cam back in, now it's timing for the cam gear, where do I go from here?
