engine starts HOTTTTTT> carbss? please help me!!!!
axeugene27
Over 1,000 Posts
So got some new mikuni vm30 carbs and put them on my cb350 set ignition timing measured and installed my throttle cables (they are perfect). I have the air screw set to 1 1/4 turns out and set the idle screw so that there is barely an opening on the slide. Here is the issue--> When i get the bike to fire it has to have choke on. When it does fire it goes into this high rpm state. If i try to back off of the choke it bogs down. I can rev from the high rev state but this motor hasn't run in years and i don't want to get it revving so high. Here are the needle/ jet settings. they were supposed to be set up for a cb350 but idk what is going on.
220-30-6f4-159 p-5
any help would be awesome.
