Engraving engine covers....
sl8rxlr8r
Buy the ticket, take the ride.
So... this is the result of my first attempt at engraving one of my engine sidecovers. I know the whole 'lucky 13' things is beat to death. BUT I was born on Oct. Friday the 13th, and used to be fairly lucky, so I feel justified in using it.
First...
I designed it in Illustrator, and had it cut on the vinyl cutter at work. Then I removed the positive space, and masked it. Then I cleaned the side cover with a quick scrub with some mothers.. then apply the vinyl. I made a little holder to securely work on the sidecover in.
I went to the hardware store and bought a metal marking/etching tool. I used this to give some cross hatching texture to the eyes.... but it was just too much to try and do the whole thing with it... So, recently i picked up a 60 piece Rotary Tool set from Harbor Freight on sale for 8 bucks, and it came with all sorts of little grinding bits. I used the little diamond grinding bits to Finish it. Don't press down hard, or you won't be able to stay on your line. Let the speed of the rotation do the work of removing the metal. The vinyl helps keep the area you don't want engraved protected in case you slip a little. It didn't take too long at all. Then i went back over it with the fine point awl to add some cross hatching and sharpen up and little details.
I plan on trying again ( i have several spares)... I've also been keeping my eye on engraving tools on ebay and such, but they just seem to go for way more money than I'm willing to shell out for something I just wanted to mess around with... Its not as clean or crisp as I'd like, but not bad for an hour with an 8 dollar knock off dremel. Should look cool once I polish it on the wheels.
That looks great! I've been considering something similar, but was thinking of some sort of blasting media using the vinyl as a mask.
I've seen glass sandblasted with a vinyl mask, and blasted pretty heavily leaving crisp edges on the mask. So there is vinyl out there strong enough for this application, just need to find it and try it.
I talked to a couple of glass blowers who use the sand blasting technique. They just use lots and lots of masking tape. (about 6 or 7 layers)
there is an accessory for dremel very similar to a drill press, with it you can set the depth and then focus on staying with in the lines. i got one, it's cool
I plan on using the vinyl/sandblasting to put some sort of design on my rearset plates, MC cover and the tank badges that I need to make yet. Should look pretty cool. I figure if I polish the badges first, then blast, then paint leaving the paint in the blasted areas, should turn out pretty sweet.
I'll check with my wife - she did some glass sandblasting at Sheridan back in the day, and i'm sure used little vinyl stick on letters. She blasted some glass juice bottles to hold spices, and has the spice names left unblasted. It took off a lot of glass and left perfect edges on the letters.
