dakine_surf
"Stay Thirsty my Friends"
Ok so this originally wasn't going to get a build thread because I wasn't considering it a project. I was just going to ger her running and ride it for a bit since I gave the last one I rebuilt to my dad as a gift, I am without a running bike at the moment.
Well that was more than a month ago, so after rebuilding the Carbs and getting her running, I am now drifting towards a mild build. It is going to be fairly simple and clean with a little brat style and a little cafe to it. I have another bike exactly like this with lower miles but is having some registration issues so it will be saved until i go all out on a full muscle/vintage fighter build.
I don't have any pictures of when I got it, but it was fairly clean, small dent in the front fender, but no real issues. there are a couple rust spots as this was a Costa Mesa bike and got a little salty.
I started by pulling the carbs and totally rebuilding them. I wish I had taken more photos so people could use it for a guide... this is my 4th time rebuilding these Hitachi carbs, I can almost do it in my sleep now. If anyone has questions about the little prickly bastards, let me know, i would be glad to help.
The First thing I always do with Carb rebuilds is clear a space, and go one at a time... I always make sure things are organized and each carb has it's own space for parts.
I then rub each diaphragm with silicon oil... it seems to do a good job soaking into the rubber and softening them a bit... especially since the Hitachi replacements are like 180 each
This shot just came out cool and I ended up playing with it a little in Lightroom 3, now it is an 8x10 in my room
So the Yamaha 4cy bikes of this era had this YICS system (yamaha induction control system) basically it allows the carbs to "talk" to each other via a vacuum channel. This is a very basic explanation, but that is essentially what it is. It can be a pain for tuning, because without blocking the carbs off individually, you can never get a proper sync. A YICS tool is sold by yamaha, but i think it cost about $300, so I made one myself.
It is pretty simple, just some stainless tubing, a spark plug wire, some high temp silicon tubing, a few washers and a wingnut. I can provide a better write up on it if people are interested.
And the finished tool.
Then I got the carbs back on, color tuned them, synced the carbs, and buttoned the motor up.... or so I thought.
You can see here where the bonehead previous owner decided it would be a good idea to drill holes in the stock airbox to "give the motor more air" which in turn lead to a poor running bike and part of the reason I got it for $300... a little silicone, and it will get covered by an extra set of airbox covers i have from the other bike.
Well as I said, put new oil in her, I got her running,drained the oil, check for metal shavings... check, everything looks good. then I changed the oil again, color tuned and carb synced... she really was purring, but then i noticed a little oil leakage around the valve/cam covers on the left side... bummer, thinking I needed a new gasket, I grabbed my impact wrench and what do i find? well the bolts and relatively loose, so i start to take them out and realize they are stripped, not the hard stainless bolts, but the soft threads of the head... damn, thats why it was leaking...
So now I scrambling, clean out each thread, realizing that 6 of the 8 are pretty much FUBAR'd, I grab a thread repair kit i had squirreled away, mix the putty up and go to town following the instructions. Now I had pretty good results with this stuff one before on the transmission of my Infiniti FX35 whan I accidentally striped a bolt in the Trans while draining the fluid. Not this time... the stuff wouldn't set up and I was left with a mess.
I called Permatex (they make the kit) and apparently the stuff i have is expired, only has a 2 year shelf life i guess. So back to the autoparts store I go only to find out the 3 local store's stuff is all expired too... f my life... A new kit on order arrives tomorrow, but i have this feeling it will be coming from a big warehouse in LA and is probably expired too. So I am hoping for the best, but expecting the worst... if it doesn't work i will have to heli-coil it which I am not looking forward to because the motor is in the frame and the holes are at an angle and not quite level.
Well that is where I am at now... Once I get this striped BS behind me, I will go on to rebuilding the forks, and brakes. I am looking for forks to do a swap with, but i really don't want to take this build to far into the stratosphere. I also want to swap the wheels for XS750 or XS850 7 spokes. Not sure if it can be done, or how hard it will be, but it would allow me to put a disc in the back and get rid of the drum. If anyone knows if the axles are the same, that would be awesome.
Unfortunately I move in a few days, and my new place does not have a garage or room for a shop... luckily I have had this thing in my Dads shop, which is about a good as personal shops get... only thing it is missing is a professional paint booth. But it is 45 Min away from my new place so progress will be slow. honestly I am just glad he is letting me keep all my projects there... I have a couple BMW's and 66 Mustang project that he is letting me stash there too, so it is a big deal for him to do that for me... I think the shop is about 3000sq ft so space is tight with all his projects and our joint tractor project.
One last shot that turned out cool... also ended up as an 8x10 in my room.
