Exhaust and muffler
A bit of advice needed from those more experienced ones! Do you guys think the muffler is too close to the rear tyre?
Thanks,
Thomas
P. S. Sorry if I am hijacking the thread ;-)
stroker crazy said:
Only if you spend too much time with the bike idling at the lights!
Crazy
Well I ride to work through Mosman and Neutral bay... so idling at the lights is pretty much all you do in peak hours :-(
Hi Thomas, if you look on page 93 of the thread The SkyTeam 'Ace' Resource you will see my exhaust is exactly the same (noisy type). I have no problems what so ever with exhaust heat on tyre. I'll try to get a good photo of muffler bracket on mine as it tucks the muffler quite tight away. The bracket has two 90 degree bends in it. Cheers, Tad.
Here you are Thomas, this makes it tucked tight in.
Allright! All done, sounds great, looks great and performs great! Stoked!
Thanks again for your help guys!
(sorry for the bad quality picture)
Looks good, are you sure it's a silencer and not a WW2 bomb (only joking ;) ), bet it sounds great.
Wow thats really short. I expect that it would give it some low speed torque?
Here's my new header (from ooracing) and muffler from flea bay.
Sent from my XT925 using Tapatalk
Updated Photo in the sunshine.
Clipons, bar mirrors, removed airbox, relocated smaller battery, tidy electrics.
2,048 Km
Nice patina on the stainless exhaust. I would say it's probably a tad louder than what would be deemed legal, but only when winding it up :-)
uc
My want to do list:
rev counter
better rear shocks
New/better brake pads
lift the gearing a notch
rear tyre
Oh and one of these cool air filters:
Some More images of modifications.
Key now under the seat.
Removed rubber fork covers
Removed black metal bracket assembly from the front.
replaced headlight with 7"
Made DIY Aluminium headlight & indicator mounting bracket.
New Rev counter & speedo
Mounted Rev speedo
Rewire cluster with new connectors to fit.
New RFY rear shocks - Massive difference!
Hi Steveo, Looking real good. Nice dampers. I have fitted what seems to be the same clippys, I then changed switch's, smaller master cylinder and lever clamps to tidy H/Bar dept (no clutter now) Feel free to take a look. TAD.
Great day today.
Went for a blast on my FJ1200 300km round trip, beautifull day!
And finished my DIY snail cams for the rear wheel/chain adjuster.
Got rid of those dodgy pushbike looking adjusters...
Last mod to do is a quick throttle 1/8 twist. But probably next year as I am just going to ride it for now.
Have another project I am starting on.
I don't really do build threads. But it most definitely will do the ton, and in a quick time too
RZ350
