Exhaust coating on the cheap....
Brian8011
I'm 90% done with my '74 CB350 rebuild, but the last bit of pesky business is getting the exhaust refinished. I'm looking for a flat black coating, but I haven't really been able to find a good product. What have you guys used? I'm looking to keep it somewhat cheap.
500 degree or better VHT, PJ1, Duplicolour Ceramic or something of the like. All will work about the same, all come in Gloss Satin and Flat black, or Silver, and all are cheap. AutoZone or Z1 for the PJ1.
Yup Duplicolor Ceramic high temp paint is what I used. Rated to 1200 degrees F. Local guys named Motion carry it, 7 bucks a can. You need an oven to bake it at 400 degrees for an hour an a half. Im sure it would work ok even if you didnt cook em.
Works awesome, even thought I wraped my pipes also.
BTW - if you're wondering why your word got masked with ---- it's because it has the letters "r a p e" in it. Wrapped has 2 p's.
"r a p e" is on the banned list of words as earlier in the day we were getting spammed with some pretty offensive bot posts. A little odd that it picked out the letters in the middle of a word however - this is the first time I've seen the board do that.
I cut my CL pipes right before the mufflers so they are pretty short. The left one fit fine but the right one stuck out of the oven a bit, we put some metal over the top of the opening to keep in most of the heat.
Like I said, you would probly be fine without cooking them. I messed up the first time so I had to sand off the paint, it was harder to get off than the chrome, its awesome stuff..
I used some VHT stuff on my 360
I didn't bake it and it started to burn off before I wrapped them.
The VHT, like I used, cost $7 a can. Even if the BBQ paint is $3, it doesn't really seem worth the trouble to do the same job multiple times.
--Chris
