exhaust fabrication questions
diesel450
"Fast with a past"
DTT BOTM WINNER
Okay, researching exhaust here. With the help of a buddy with some tig welding skills I'm going to have a go at fabbing an exhaust from scratch. Found some cool stuff thanks to stiks links. I'm looking for some discussion here. my thought is 2-1 with a 2" outlet into the muffler. sound reasonable or should it be more restricted? also as far as mandrel bends are concerned am I looking for 2.25" radius or 4.5"? I don't have the bike in front of me for measurements at the moment. I'm guessing that that bend radius will effect how far the down pipe extends from the frame at the flange.
looking at this kit http://www.mandrel-bends.com/catalog/builder-kits-33/ultimate-builder-kit-111/1-50-od-4-50-radius-16-gauge-mild-steel-ultimate-bk-895.html
give me 3 or for exhausts out of it.
check these bad boys out from Cone engineering!
http://www.coneeng.com/pdf/Motorcycle%20Webpage%2011_1_10.pdf
Diesel, there was a link posted by revhedgl about tuning exhausts. Don't know if you saw it, but it was in the "2-1 exhaust" thread.
I can tell you from my experience, that 2 J bends were enough to make this exhaust i still had a little extra too, not much but if i had screwed up i woulda been heading back to the store.... These are what i used. 1 5/8" diameter, i think 4" radius, http://www.holley.com/12342HKR.asp if you look Hooker sells some different radius's I wish i could comment on sound or tuning but i haven't got the bike quite finished yet, got a little bit more to go, but soon enough
I didn't wanna use the old flanges or cut up the old header pipes so i decided to make my own flanges on my small lathe, I used a small piece of DOM tubing, but solid could also be used just more work involved... the dimensions are there too, although i suggest you check them against a stock collar to be sure, also if you use a different size or make of pipe the ID might change.
If you have any questions id be happy to help out, good luck with your project.
Hey, thanks! That is great info, and your setup is very close to what I want to do. I don't have access to a lathe at this point and I also don't want to cut up the headers. one thought I had was to use a larger diameter tube over the header to create the flange and weld that in place. If I got you measures could you turn something out for me? be nice to have something that clean.
Thanks for the input.
You didn't say what size bike the exhaust was for, so it makes it a bit difficult to recommend a size. I build mine out of 1.5" OD, .065" wall stainless. A 2" outlet is pretty big; I'd shoot for a 1.5" outlet.
I buy my 2-1 merge collectors nowt, but this will give you a pretty good idea of what I did: http://www.motofiaccone.com/moto/40-cl350-cafe-racer/121-newstainlessexhaust
I'd buy 3 J bends (if you go that route) just in case there is a mistake. Personally, i started just using 90 degree bends, which though more expensive, I like working with much better.
I like to buy the tightest CLR bends I can, but it's down to preference.
--Thanks, Chris
Those stainless reverse cone mufflers from Cone Engineering are the mutt's nuts. I haven't seen those before. Those things are incredibly cheap, and I'm going to order one to check them out! Great find.
They look to be more a muffler, though, than a reverse cone megaphone, but it still looks like a great product.
--Chris
Chris, I was hoping you'd show up. thanks for the info. I will study carefully before I start cutting. I like those weld on reversible mufflers as well. could create a pretty gritty look for certain applications.
I was thinking the j bend would allow me to manipulate the downward angle from the flange and then the turn under the motor a little more closely than a straight 90, but I see you like those straight lines. The stuff is pretty cheap I may order a variety of options to play with and see what we like.
Here is the header I started building today for my reverse port. I used 1 1/4 inch tubing for it.
That is decidedly not an equal length header.
--Chris
Hahahaha! Brother the first one I built was equal length but I really wanted something a little more eye catching so I built this one! And after doing some research unequal length tubes help to broaden the torque curve.
By the way i forgot to mention mine is a 2 into 2 setup, the muffler is mirrored on the other side. I suppose if you want some collars made up i could help ya out, i would just need a accurate measurement of the OD of the pipe your using, then i could turn them up fairly quick. Long as steel collars are ok, My small lathe has enough trouble with the steel, stainless would be a lost cause. If your interested let me know, otherwise feel free to use my design, and get them made locally, Im in Toronto just so ya know...
Joey, That is Craaaaazzzzzy!! nice work! I'm betting you don't sleep much!
Chris, great photo tutorial there helped alot. one question; I assume that you made those slip joints from straight stock, no? special tool to create the expanded section? local muffler shop? also, any problems with leaky exhaust with so many slip joints? I'm thinking I'll have the 2-1 all one piece and have the muffler slip on with spring clips.
there aren't any expanded sections, the only place it steps up in diameter is right at the muffler where i used slightly larger pipe and slid it over the smaller pipe, The adapters the mufflers came with were cheesy so thats the reasoning behind that, as for all the other joints they were just butted together and perimeter welded, I haven't had a chance to try it out yet but don't anticipate a problem as I have previously made an exhaust for my car the same way and haven't had any problems.
Okay you just opened a whole new can of worms. You mean it doesn't just have to look cool? ;-)
Thank you for the compliment Brother!
Yeah, the slip joints were made from straight stock. For that exhaust, I went to a muffler shop and borrowed their swedge tool. It is a pain in the ass to find someone that has the tool and an even bigger pain in the ass to find someone with a tool small enough for 1.5" tube.
Just have mandrel-bends swedge some tube for you. You know they sell a merge collector that has a 1.5" inlet and outlet that is already swedged for you, right? I had them make me a batch and they ended up adding it to their catalog. That is the easiest, most elegant solution.
Having one piece 2-1 exhaust is a massive pain in the ass due to most heads having the exhaust ports splayed. Even if your bike has straight out exhaust ports, it will still be a pain to make a 1 piece 2-1 header. Trust me, I've made more than a few of these things. The megaphone just welds to the merge collector.
The swedged pieces are a VERY tight fit. Swedging is not an exact science and people seem to swedge on the tight side. This means slipping the primary into the swedged secondary can be extremely difficult even when using lubricating oil to help the slide. That's how tight they are. Now, add a little exhaust heat in the pipes and the expand a bit more making leaks impossible. Look, I didn't pioneer swedged exhausts; it's continually done in Formula 1 all the time.
If you open the Cone Engineering PDF and scroll to the bottom with the springs, I really like the top version, second to the left. That is a much better design than the ones I used in the past. Have a go with those. If you have a MIG, run some stainless wire in it and tack your system up. Just turn the machine and the wire speed way down. Then take it to your TIG guy. It saves a lot of time and money.
[edited]
--Chris
There you go again Chris!
hey thanks for the info. I think I like the idea of the swedged fittings at the collector anyway. And you're right, I can see how that makes mounting easier. I'll keep at it.
Actually, that was a bit unkind. Consider it retracted.
--Thanks, Chris
