Exhaust Gasket Options
woodardhsd
Still slowly working on my CB400T Hawk, this time mounting some Emgo Shorty mufflers to the stock collector box. I don't want to weld them. I'd also rather not ditch the box as it's in really good shape and probable provides most of the muffling.
here is the colector box:
The shorty muffler:
And the stock gasket:
The narrow end of the muffler fits right into the box, but the stock gaskets are too thick (close to 1/8"). According to my 3m painters tape gauge, I need something around 1/16" thick.
Is there another material that I can use? Would exhaust wrap hold up to the heat and exhaust gas? Is there any other flexible wrap/tape I could use?
That area probably doesn't get super hot like the headers, so you can probably use some shim aluminum. I'd probably cut three or four strips that go around once so they can slide around one another as you tighten the clamp. One long strip might bind and buckle. I have a bunch of roof flashing scraps that I use for stuff like that.
You're right about the crossover being the muffler, the pipes are empty inside. I used a liquid gasket at the joint between my emgos and the pipe. It is like putty, put it between the pipe and the muffler and when the exhaust gets hot, it hardens up and stays put until you disaasmble, then it scrpaes off and you can put more on, it was like 10 bucks at Crappy tire. Works to stop leaks if you only need somethin 1/16" thick. You could use it with the aluminum flashing.
Cheers,
Well, I ended up using this:
http://www.designengineering.com/products.asp?m=sp&pid=30
I got the 1.5" roll, and split it down the middle and wrapped it around the inlet until it was a tight fit in the collector. It has worked out well so far. It leaked the first time I started it up, but by time I got back from the first ride, it had sealed up nice and tight. Hopefully it will hold up. Package says it's good up to 1500 F.
