exhaust popping help please
modest
1977 cb 750f/ 71 engine
So i have a 1977 cb 750f the exhaust has no baffle and are cut pipes so already loud, the thing is when i sit at lights in neutral it pops like a popcorn popping sound from time to time which im used to but at night recently when i leave work at midnight and its been siting for eight hours i warm it up and it pops a lot when at idle sitting at lights and even has some flames out the back but just noticed it happening mostly at night rather than day is it anything to worry about or just that its supper cold and the whole fuel oil mixture is cold??? any opinions would be great thanks
its been my experience, when you are popping its more then likely you're running too lean. if your cans have no baffle, you may have to turn out mixture screw/screws...So since im used to tuning twins (someone correct me if im wrong) I would start by turning the mixture screws till they're closed. Then turn then out (equally) 1 to 1 1/2 turns out, start the bike, and go from there. You keep going till theres very little popping on decel.
Also, you could have an exhaust leak, bad head gasket...but, it just sounds like too air.
You'll have to rejet your carbs.
Idle mixture screws are just the begining.
No backpressure in the exhaust is a no-no.
Loud but slow.
For high rpm drag racing yes,midrange torque on the street,no.
Do you have pods or the stock airbox?
Are you running the stock Mikunis?
Try this little test,tape off half of the suface area of your
filter(pods or stock) and note how it runs.
