Exhaust port damage
Looks like it has been repaired before? Is the head off the engine?
I know a guy (AC - member here) who does aluminum welding. I'd have it filled in and then drill/tap the hole again. Is that the hole to mount the exhaust?
I have not pulled the motor from the bike yet. I am waiting on 2 new shift forks to come in and once i get them in ill pull the motor and take the head off to get it fixed. I went and looked at it again on my lunch break and it looks like the crack goes into the head about 1/4th of a inch but its not inside the port.
I took the head off and too it to my machinist he looked over the head. he checked out the crack and we found that it does go into the port so we both decided it would be better to get a new head. I got a bare head off ebay last night and he is going to swap out the internals for me. I went ahead and ordered a gasket set and a new timing chain for the motor.
Since i have torn into the motor this much is there any other things i should replace or do while i am waiting on the head to be finished? the motor only has a 4200 miles on it and i did a compression check on cyls and one was 165 and the other was 160.
Those are good PSI results from what I can tell. Wouldn't bother with rings or anything. I presume with the new head you'll have the valve seats lapped etc? Just a standard 'valve job'. Replace the valve stem seals of course too.
Might consider whatever cam chain tensioner guides are in the engine - they're consumables and should be replaced when you have the engine open unless they're in excellent shape (or you can't buy new ones).
If memory serves me, the cam chain in the 450 has a master link correct? Or did you have to break the chain to get it out (if you've removed it)?
The chain did not have a master link so i ended up having to break it to remove it. I downloaded a service manual and checked the specs on everything and everything seemed to be in tolerance according to the service manual. I pulled the jugs off to check the rings and found 2 of the rings were cracked. one on each cylinder. I got some stock piston rings on the way to replace the broken rings.
I dropped off the core head i ordered at the machine shop for him to grind the valve seats, clean up the valve, grind the valves, hone the cylinders and check over everything. He gave me a call this afternoon and told me the exhaust valves sealed up nicely but one of the intake valves did not look too good and i would run the chance of burning the valve. He suggested that i replace the valve.
So what are my options for valves? I checked out Ebay and only found stock valves for like 30-50 bucks each. All the racing sites i saw sell the valves for 50+ which seems to be crazy. I checked SI valves but they don't seem to offer any options. Anyone know of any other options?
