Exhaust valve leak
SONICJK
Reminds me of...me No, I'm sure of it. I hate him
This is my first time dealing with valve leak so any help is really appreciated.
So my bike (cb350) is sputtering a bit in the high rpms and feels a little down on power so I decided to do mu first leak down test.
Turned it to TDC on the left cyl and zero leaks at 90 psi.
Turned to TDC on the right cyl and I have massive leakage out the exhaust. Shit.
So I checked compression, I'm at 160 on that cyl so all is well it seems?
Played around with it a bit and adjusted the valves (didn't help), then I started turning the engine slowly. Low and behold, the cylinder seals perfectly right here:
which looks to me about 90 degrees before top dead center.
So im at a complete loss here, seems to me like the cam timing is wrong, but the other cylinder is perfect so that can't be the case.
Does anyone have any ideas? Am I missing something crucial?
The bike starts right up and runs fine, but the powers low (both cyls are firing,but I assume half my power is going out the exhaust) and it sputters at high rpm.
I have experienced valve stems with crud built up on them that would make the valve stick open a little sometimes and cause an inconsistent compression reading. One stroke, the needle would just just like you expect, and another stroke the valve wouldn't seal, and the needle wouldn't jump. I have seen worn valve guide do the same thing. Sometimes the valve would land right, and seal, other times not.
ADC,
Thanks for chimin' in.
So what is the fix if that's the issue?
I was thinking start with a good jet of carb cleaner on the back side of the valve while it's open through the plug hole.
I really, really don't want to tear the engine down again right now.
And now that you mention it, I believe I did notice the needle move sporadically like you describe the last time I did a compression test.
I guess a little more testing is in order
It's worth trying to clean the valve stem. What have you got to lose? Could be some oil has hardened on the stem from heat and gummed it up.
Also, give the Seafoam engine treatment a try. Some in the crankcase, some in the intake while the engine is running. They have good instructions for how to do it with cars. I have done it found it to improve an engine that has stuck rings. Maybe it would help a sticky valve.
ADC really appreciate the help man.
I'll give It a try and report back
Holy shit.
Put some seafoam in the gas and a bit in the oil.
Also pulled the plug on the leaky cylinder while it was hot and dumped some seafoam in there to boil into the valve.
Jesus. Its a whole new bike! More power than ever, and for the first time since I've had it I rode the piss out of it tonight and when I put her in the stable she was humming along happily without a trace of smoke.
