Exhausted: info wanted
cb350g
I have some kind of random after market pipes on my 1973 CB350. Whether due to a leak, or removed baffles, or something else, there is little or no back-pressure and my bike runs very lean and hot. I think that's bad. It backfires on deceleration and is starving at high rpm and I suspect that's not good for it.
Here's the pipe
and a view into the end
Am I right in thinking there are no baffles in these and that would be causing the lack of back pressure?
So if I were to just replace the pipe, are there any pipes that are quiet, provide correct (i.e. some) back-pressure and don't require rejetting that are actually available? I've seen four possibilities but don't know very much about them and am having problems finding any info. Looks don't count that much to me, and sound only in that I don't want it to loud, while of course still prefer a low rather than high rumble.
Motad: I know nothing about these.
Dunstall replicas from JCW: Seem to have a removable baffle but don't know whether they are loud.
MAC: don't require rejet, but they are loud?
David Silver spares: sells pipes, but they say NOTHING about them, not even manufacturer. Anybody know anything about them?
Any other opinions on exhaust options for the CB350 twin at all?
I'm sure there are minimal baffles in those cans, they fell off some rattle-bag Harley. Were it me, I'd just rejet the carbs are tweek the timing to suit. You'll get batter power and depending on your right wrist, possibly better mileage. As well, with the correct mixture the exhaust note will be nicer.
The fact that came off a Harley is very helpful! I can search for possibilities now...
I'd be OK to do that, but "rejetting the carbs" is not minor to me. It seems like a bunch of work to match the carbs to something I don't even like very much... the tone is good... but they are loud and kind of annoying. I'd be more open to putting baffles in the pipes since that would probably go a bit of a way towards fixing both the loudness and the lack of back-pressure. But other than stuffing steel wool in the end, which seems like basically never works, i wouldn't know where to start to get baffles that would fit these mufflers.
Time to search the web some more unless you have other ideas...
