Exhuast Stem Missing
hecklejk
Hey Guys ran into this problem last night when trying to hang my new exhaust. On one side of the block where the Exhaust pipe meets the engine block there are 2 stems with thread on them that you attach the exhaust flange to, the other side of the block only has one of these stems. I assume that the previous owner had a problem with this stem and it either broke off or came out. His brilliant idea was to just use a bolt that about the same length and 1 thread bigger. This worked until I changed the exhuast out and realized that the bolt he used is now stripped. I would like to put a stem back in place of the missing one but I am not sure what size to use and how to get it to stay in the block. Any ideas would be greatly appreciated.
FWIW... my solution...
Retap the hole and put in a new stem bolt. It will be different than the others but at least it will be proper.
As for determining the proper size, take the stripped bolt as a starting point and go up a size from there. Don't forget the red loc-tite in this hole as you don't want it backing out on you.
You may have to use a shorter bolt as the tap may not be able to properly cut new threads all the way to the bottom of the hole.
I had to do this on my heads for the valve cover centre bolt... a pain to remember but it does work.
Thanks for the tip, that is what my buddy suggested, I will give that a shot next time I am in the shop!
