Explain carbs to an idiot
chilli
Learning, swearing, breaking, fixing, making.
I'm slowly trying to overcome my lack of knowledge of things mechanical via a project bike. One ting I'm having trouble grasping is the whole concept of carbs, jets etc.
For example, if I change the air filter or use an aftermarket can that's more free flowing. Those that know all say stuff like "you'll need to rejet the carbs" and other sage-like phrases. So, here's the deal. I know the basics of what goes on inside the carbs, i.e. jets, fuel/air mix etc but that's where it ends.
So, how does it work? If I change the air filter to a more free flowing type what happens to the mix, what do I need to do (i.e. more air larger jets) and how do you quantify it (i.e. jet sizes - needles, hmm there's another unknown)
Hope this makes some sense.
I'm really looking for a general concept how how it all relates rather than detailed specifics (unless that's what I need) so I can understand the principles then apply them to whatever bike.
Cheers
Look for a thread called "Motorcycle carb theory 101" or something like that. Should be stickied in the 1800 cafe help section.
There's so many variables that go into the process (air velocity around the intake, pulses from the valves, etc) but basically an engine needs the perfect mix of air and gas. Once you put on a free flowing air filter, the carbs are getting more air and not enough fuel. Hence, rejetting.
Big rich called it right on that thread.
In principle it's simple, as engine speed increases, the velocity of air through the carb goes up and that creates a lower pressure and more fuel rises through teh needle jet. Bernoulli's theory http://en.wikipedia.org/wiki/Bernoulli%27s_principle is that as gas speed rises, pressure drops.
In a carb, we have the low pressure in the carb throat and atmospheric pressure acting through bleed vents onto the fuel in the float bowl. It's teh pressure difference that works to suck up the fuel or more correctly, blow it. Air filters and stock exhausts are designed to make optimal power with minimal noise and teh jetting is designed to work with those parts in place.
Change the pipes or air filters and the flow will change as will both the velocity and the pressure. All we are doing with jetting is to try to bring it back into balance with the right proportions of fuel to air.
dirtbag said:
It was invented by Karl Benz of Mercedes Benz. He also invented the clutch.
The carb. Yes and it works on Bernoulli's principle. What is most amazing are the things that were invented way back before computers or internet or even much in the way of communications. Some very smart people.
Thanks for the info. I actually have the original pdf that the post came from on my mac at work. Just need to have a proper read of it.
I guess the best is I wait til I do something specific to the bike and do my brain picking then.
Theres also this neat thread by... boingk I think his name is? ::) Anyway, it goes into a lot more depth with what putting pods or an aftermarket exhaust on your bike actually does to improve performance, and why you then need to modify your carburettion accordingly.
Its called 'Tuning for Modified Intake and Exhaust' and is on this board.
Cheers - boingk
Cheers - boingk
Thanks, I did read that. Great post by the way, I've bookmarked it to go back to a read again.
The bike's a runner with so I'll probably take my time, as I'd like it to stay that way ::). There's plenty of bits to be getting on with and this is my first crack at this so I'm in no rush. It's a lil SR250 I picked up as winter project so I'm not sure how much "performance" can be eeked out of it... I'm having fun though so that's the main thing
Ah, an SR250... theres a good build going on at the moment using one - be interesting to see what you do to yours!
On the power note, theres a mob here in Australia that cracked 120mph with one on the salt flats. I think that equates to more than double the stock output, crazy stuff. What exactly do you plan on doing to tne engine?
Cheers, and thanks for comment on the Tuning thread - boingk
The thought of doing 120 on my SR makes my nuts run for cover!
So far just tidying up. Swapped out the mini-ape bars for some trial bars (not sure about clubmans as my back,s fecked...) bar end mirrors, new clutch cable, fuel line, bit of paintwork and general clean up. Going to try a seat build too.
Before I look at getting the thing to go much faster need to look at the wheels and shockers as they need a little love I reckon. Either going to clean or replace the air filter. Like the idea of a pod filter but wonder if that's going to mean a bunch of changes to the carbs. Managed to squeeze it up to 110kph and quite frankly it feels like it's about to fold underneath me. Going to change the fork oil on the front and (maybe) get new shocks for the rear. Wheels need tuning as well I think.
As this is a first crack at this I'm not sure whether it's best just to try and get the stock setup running as nice as I can rather than changing too many variables and ending up with a cr@ppy setup...
