Explosion Risk & Brazing
CresentSon
Over 1,000 Posts
So I have witnessed some debate on welding tanks, and the bad things that can transpire. Using my ever keen intelect I have concluded that brazing would bear the same risks.
I plan on brazing in a fuel line 'gauge' and have not been able to find the info I need. Basically I don't know how to braze, or what metal to use, or whether I need to braze or just use silver solder. Once those problems are lined out I'd rather not blow myself to hell. I found a $20 torch kit for silver solder. Would that work, or do I need an acetylene rig?
This is kinda what I'm after.
What advice do you have, it just might save a life.
Silver solder melts at a much lower temp than typical copper filler solder, so a decent torch should do the job. Make sure the entire area to take the braze is hot enough for the silver solder to melt in! If it is not, it will set with holes in it! Also silver solder will not bond to steel, so I am not sure your gauge could be brazed in that way! If you just use some iron tube you can drill holes on the tank and braze them on with a torch and a metal coat hanger as a filler rod. My uncle showed me how to do that as a kid working on old hotrods! You will need a good oxy/acetylene rig for that type of brazing. You can get a really good weld that can be sanded down good and smooth doing it with the coat hanger method. My uncle completed a chop top on his old rod using nothing but some hangers and an oxy/acetylene rig! Looked great too!
You can purchase some filler rod solder that has a blue or pink flux coating on them that will melt using a MAP gas torch. These will bond mutiple un-like metals and create an air/liquid tight bond. I am not sure what they are called. how much they cost, or how well they work. I have never used them!
Hope it helps cresent, good luck!
If your using any type of flame there is a risk.
Wash out tank,( hot detergent/water/etc) connect vacuum cleaner hose to exhaust pipe of car and fill with 'inert' gas.
Getting it hot also dries it
Then you can weld/braze/solder/etc.
PJ
you dont have to wash it out.....just hang it off the tailpipe of a car while its running for 20-30 minutes with the petcock removed and youll be fine.
Great tips guys. I guess I'll be picking up a torch and rig. I also hope to braze on the trim in the same manner. Been doing a lot of you tube study, and I'm gonna price a few low end rigs too. I have always wanted to learn to torch weld too, so I might look into a class at the community college. Thanks again guys, as usual you have set me on the right path.
Okay,,,,,,I did the PURGE exhaust theory,,,buddies gas tank(auto),,,,ready for this,,soldier it back together......but not with out a very little kaboom,,after the torch hit the tank,,,vapours burned off and plugged it. I modify honda tanks by eliminating the shit petcock and converting to dual petcocks(1\4 npt fittings) and petcocks from walridge motors,,,,,,working in a welding enviroment,,I purge the tank with argon before I ,,,Braze the new fittings
ok, i am just your basic welder/fab type guy. I wouldn't solder what you are trying to do. Especially if you are a "newbie" or "novice". Soldering with a torch is not easy, as silver solder has a very small working temp window for flow, and very sensitive to cleanliness and such. Not to mention that solder will not stand up to the resonant vibration.
Brazing is less sensitive to overheating, and easier to do imho as a novice. Find a buddy with experience. FYI - it does need to be VERY clean to make a good silver bond or braze, on both sides of the material as contamination flows through cohesion.
sorry to be mister buzzkill.
On the contrary Beater, sounds like you are in with the concensus. brazing is the way to go, just gotta find a rig that is affordable enough to get me through the build. I can invest more later, but this is coming out of the remaining bike budget. I have heard good things about the cheapo harbor freight rig for $100 - $130. Should do for a beginner.
Thakses wee todd,,,,might try the dual petcock conversion too,,,,,no KABOOM for dis guy.
For now I'm reasearching which metals to use, brazing rods, etc...
Fairly good info on you tube and wiki.
true filet brazing is as hard if not harder than oxy fuel welding. A bare bones oxy set up will run you 450 for anything you would want to own. Then there's the practice times. I am not really trying to discourage you, just providing the other side of the argument if you will.
Everyone who asks me how to learn to weld, I say "learn torch first" but like everything these days, people don't want to wait. I will say that you will get every dime you put into an oxy fuel rig back, and then some. There is basically NOTHING you can't do with one. Cut, weld, braze, solder, heat shape, the list goes on. Hell, I have been known to stoke my wood stove with the rosebud tip.
Find a buddy close and watch him do the tank, and practice on other areas. The one risk on brazing on sheet forms like a tank, away from a seam is stress relieving the form. Meaning it could miss-shape the tank. geez - I am full of cheer this morning.
anyway - if you were in denver, I'd hook you up for a twelve pack. I am sure there are others around you that would do the same..
j
