Extremely bad wheels!
chrisf
Over 1,000 Posts
OK, as mentioned here (http://dotheton.com/index.php?topic=2879.45), I screwed up my wheels over the weekend. Does anyone have any idea how I can right this terrible wrong. You can see in some of the pictures where WD-40 and 600 grit will make the wheel look somewhat presentable, but what about the inside of the hub, betwixt the spokes? It will be proper hard to get a wire brush in there...
Is there any sort of environmental unfriendly solution I can dump on the aluminum and rinse it off?
Any help is appreciated.
--Thanks, Chris
You can try to brush on some CLR. Or maybe POR-15.
http://www.por15.com/prodinfo.asp?grp=MR&dept=2
ok, panic attack under much better control. A brass wire brush knocks the oxidation right off and gives the wheel the dull cast look. It much more work than I planned and I have no idea how I'm going to get the inside of the hub. We'll see.
Thanks for the advie DrJ. I may need the product yet.
--chris
Careful application of some glass bead blasting might be the trick.
I've got a couple of bottles of metal ready if you want to give it a swing
uuuummmm spokes from honda will only but you back around $80.00..a complete set to go!! now the rim is ready paint it! and then get it trued,,,,,,,,,done deal!!!!!!!!
If you were going to spend $80 on spokes, buy stainless Buchanan spokes/nipples. Somehow I doubt the Honda OEM replacements are stainless. Standard spokes shouldn't cost more than $40 a set.
I suggest a bead blasting job and some rattle can paint. My guess is the oven cleaner ate the clear coat on the hub. Those wheels are similar to a lot of the early CB wheels - CB200, CB160 etc. You might be able to locate another set fairly inexpensively on ebay in decent shape if all doesn't work out with the ones you have. There is a real nice looking match set available on Ebay. two different auctions by the same seller one for the front wheel and one for the rear. They are even in Canada so shipping would not be bad. The auctions are currently at about 11.00 each with 1 day to go. Here is the item number of the front wheel 130205956553. The rear is listed in the sellers other items. I would consider this route rather than all that cleaning up. Here is the link to the listing - http://cgi.ebay.com/ebaymotors/1980-HONDA-CM400-CM-400-FRONT-RIM-18-X-1-85_W0QQitemZ130205956553QQcmdZViewItem?hash=item130205956553 - Good luck. -MBS
gents:
Many thanks for all the suggestions. With a ton of elbow grease, they now look presentable again. Those following my build in the big arse projects section will remember that this is a gift to my brother. He makes money, so he can go the whole powdercoat / stainless / ali rim route on his own dime.
--thanks, chris
buchanan's spokes are priced from $80-105 for stainless kits,and they only ship by courier,add the same amount for shipping to the great white north! that makes the honda(plated) spokes more reasonable..and they are probably cheaper in the states!
East Coast Wheels sells Buchanan spokes and has more reasonable shipping to Canada. I paid $25 shipping + $80 per wheel for my custom stainless spokes for my XS650.
