F*&% HELP, working on carbs, pilot needle
reelinfeele
OK, if you have run into this let me know. Finally got around to cleaning carbs properly. Some previous owner decided that the pilot needle was not tight enough. The needle part at the tip is broken off in the carb body. KZ400, the pilot circuit is on motor side, so according to carb theory 101 it regulates fuel. I will be running cone filters so I need to be able to back this needle out.
Has any one else run into this? How can I get it out. ?? >:(
so maybe its the pilot air screw that I am talking about. It is all the way in. SO does that mean it is richer with fuel?? It is after the slide, closer to the engine. So it should just affect the airflow.?????
With seperate pod filters, I would want to richen it up (more fuel) RIGHT?
It's a fuel screw.
You should be able to press out the broken bit as they usually stick into air passage.
Kawasaki probably sell new ones, no idea of cost (Suzuki and Honda sell them, I don't 'do' Kawa's)
If it was a Harley, you have to buy new carb (although I have made them)
Thanks for suggestion. It is an air bleed screw...??? There is no other side to it without destroying the carb body. I think I have an idea though on how to fix.
If its on motor side, it's fuel screw
The outlet will be visible.
Should be able to prod at it with a small pick.
If its an air screw, it wont have a needle tip
there is a small hole in bore just past butterfly. so fuel must come up through cab somehow. damn, so I have to get it out. thanks. I have tried a small drill bit in that hole to get it out. Its tiny. whoa is me. to the machine shop...
Glad you found outlet.
It's going to be between 0.25mm~0.5mm, (I have measures needle tip but can't find drawing)
Don't enlarge hole or you will never get carburation right and will need new carb body.
i actually had the exact same thing happen on a friend's kz400.... strange.
I couldn't get it out, so I drilled the opposite side of the casting with a 1/32 bit I believe, then pushed the broken tip out with the shank of the drill bit, then I used some jb weld to plug the hole, worked like a charm, even though those carbs were moderately fucked from the previous owner... read - used sheet metal screws for the diaphragm covers...
the good needle on other carb measures .040 taper to .030. Buddy at machine shop says he can grind a drill bit with that taper and drill down whatever the depth is.. my pubic hairs will crossed for that one. thanks for the tips guys. I will keep posted. weather just broke to resaonable here in FL, time to ride. Dont think biketoberfest will be in the cards this year. Maybe a trip to swap meet.
reelinfeele said:
the good needle on other carb measures .040 taper to .030.weather just broke to resaonable here in FL, time to ride.
;D
Yep, got out on 360 this afternoon, if only for 40 mins, it was fun. 8)
Put helmet cam on and got 33mins of video (first time I've used it :D)
Pretty sure the hole is parallel not tapered
