farmer92 said:Was mocking up a shitty fibreglass inner fender when i realized i probably would want a bracket across the frame at the top to help stop it vibrating to pieces.
teazer said:Those will fit with a little welding and moving studs... I went through as similar exercise for a GT750 - looking at RM250 top ends and triple sled cylinders and the issue on a triple is that two of the cylinders are too close together and that would require changes to teh crankcases as well as crank spacing and that all made my head hurt.
I think the 500 has wider cylinder spacing than left and center on a 750 triple, so it might be a touch easier to fit something less antiquated. Maybe a pair of XCR800 cylinders and case reeds might work for you.... Or maybe build this motor and keep thinking and build a spare big hp water cooled motor.
farmer92 said:Teazer, i have an old set of O/A tanks, but they are way past their pressure test date, i’ll have to ask what the protocol is when i get my shielding gas filled.
irk miller said:I haven't had an issue exchanging tanks at either AirGas or Praxair. I normally use Praxair, but both have taken any tank I give them even competition.
A surprisingly accurate description of this header...teazer said:You do not want to see the last set of pipes I welded up. They look like they were shat upon by a blind weld pigeon.
