Father Son 75 CB200T Rise From the Ruins
Thanks guys! What was interesting on the tensioner is the wear was on the tension bolt side and well we made and assumption the wear should be on the chain side...maybe another sign of revving into the redline? The valve faces were way out of spec when we checked them however there was no wear on the rocker arms nor the cam...or too lean? Oh and I won't tell you we forgot to put the tensioner in the first time we set the head :(
Tdc on crank
Spark advance knock facing upward and points to the line on top of the ear.
Blue permatex on cam sprocket bolts
Cam sprocket diameter line is parallel to the top of the head.
Good?
Picked up a Stockton rivet tool for 30 bucks...but I had to buy something first so we got a sticker.
Never done this on a cam before the plans are to match the surrounding link flares
using the small anvil.
Here is the honda riveting tool since these are solid links i am assuming you press from the back of the master link and have the anvil in front to receive the stem as it is pressed through the link????
When your gut tells you to wait...wait. Found this little gem about the Ek timing chain.
I had some issues with that on my CB500. I ended up modifying my tool after some measurements to press it perfectly down without crushing the plates together. That sucker isn't going anywhere...
Thanks MotorbikeBruno!
Hope it helps. The same tool you have destroyed 3 master links in the process...until I ground it down to make the necessary clearances. I figured I can buy the replacement kit if I need it at a later time. Good luck!
we are drilling out the pressing plates to match the cam master link...I have two links so I need to learn from you...lol
my buddy Steve dropped by and I showed him the email and he said hand me a vice grip and a screw driver...lol..and this is how long it took
http://youtu.be/kSEllc9j95w
Lucky got some new bling for her casing and we found a good 10 buck throttle cable at the bone yard and did a little die work. We really like her gauges so we lowered them. My son gave her first taste of 10w40 partial synthetic. We drilled out the controls to feed the wires through.
We have turned our new motor over with the starter for about 30 seconds and have the tappet valve covers off. Should we see oil?
--I responded to your other post with this same answer first. Thought id re post for continuity.
Did you use cam assembly lube on the cam? It may take a while to push out the heavier lube from the holes in the cam lobe.
30 seconds isn't very long for that tiny pump to move much oil.
I turned mine over for a while, then pulled the stator side cover to check if there was oil in the galley which goes to the crank and up the studs to the head. Sure enough there it was.
Upon replacing the stator side cover. My final confirmation was when the cam holder gaskets started leaking.
Hopefully yours is buttoned up tight.
When I switched my clutch sidecover to one I had modified for an external oil line, it was much easier to see how slowly it flowed.
thank you! We will pull the stator cover and check the galley...i'm kinda paranoid lol
We have no sparks so we checked our condensor by discharging it to itself...no spark...still alive...be careful not to touch the condensor if charged. We took our ohm meter and tried to charge the condensor...nothing. Condensor is bad.
We checked continuity on the primary side of the coil and got 4.5 ohms and then checked the secondary side to the plug wire and nothing coil is bad.
Now we have our new Dynatek Dc1-3 gl1000 electronic ignition but we are waiting to put that in after we get Lucky running old school with points.
