teazer said:
It's a DYNA on a custom backing plate and a modified rotor and shortened crank nose. OK for a race bike with total loss ignition, not so good on the street. Riddell does a magneto conversion for the 160-175-200 motors that's worth investigating for a race bike. For teh street the easiest solution is a GL1000 Dyna mounted in place of the points.
Cool, thanks for the info man, I had the same question
Teazer where did you get your casing socket bolts. I have been told to stay away from stainless??? Found chrome reasonable at Hillco. Are yours aluminum are you running titanium?
thanks Teazer u saved us 250.00 over bore tech and now Lucky has Gold Wing ignition :) It pays to wait. This build is on tracks and just at the moment we are ready it is handed to us!
Hey Tex... did you ever post pics of that CL exhaust you were thinking about running on lucky ?
yea they are in the thread a few pages back...here is one with the muffler mocked up. The baffles are rusted out but the casing is good we may do something a little different than most...cl pipe builds...need to do some calculations.
Texasstar said:
Teazer the more I look at these velocity stacks the more intriqued I am. The bases are all tilted at an angle, there is a hard spline in the center of the flute but 2/3 of the bell is flexible. Apparently they are meant to flex under use. I would like to see what they do using a high speed camera.
Hey Teazer this is texasstar juinor and I wanted to thank you for all the info you've been giving us. I also had a question about the pic you sent us of your bike. Is that you on your bike?
Les Barker also sold a pertronics ignition with a new cam trigger to replace the stock points unit. (on the end of the cam)
It doesnt look like he has any on ebay right now but you could probably email him to check.
http://stores.ebay.com/LESVintage-Advantage?_trksid=p2047675.l2563
Les and I have talked. I have read some reviews on that unit and the racers weren't real happy with it? Gossip? Three reason we went with the gl1000 dyna...the dyna reviews have been outstanding for their products. It was designed for a Honda and so far we have outfitted our gal with rear sets from a CBR600, Velocity stacks from a CB750, and ignition from a Wing. In the process all of that ended up costing less than a set of custom rear sets. How did your cam oil fix hold up on your CB200?
Did you weld the lower case shut to prevent the oil coming out? What carbs are on it (how many mm)?
Killer engine. nice work!
Thanks.
No. There's oil mist around, but it's not sitting in a pool of hot oil so it's OK. Those carbs are VM26 Mikuni and the engine is 240cc with bathtub shaped head. It's still a 360 degree crank and stock cam drive, so it doesn't rev very high. Rockers are lightened and so are the valve adjusting screws. No gear cam drive or 180 degree cranks or cam chain slippers in this. Just basic old school hot rodding.
teazer said:
Thanks.
Teazer talked to Jared at Big D and he said they have the oil cooler for nixons bike but no mounts. They said they need to look at the pix. I took more pix for you. Gene Romeros bike for the same race. Nixons 69Daytona Bike. The other bike is Nixons 68 Daytona losing bike...big difference in bikes 68-69
Thanks for sharing. Points in special housing? Check. Fontana Brakes? Check. Nice piece of history
in two weeks we see history
Denatured alcohol test for one hour before and after
Oil filter procedure
Remove screw
Insert 8 mm bolt as an extractor
Measure for tool
Order tool
Wait
Ringo said:
And I am jealous!
my oldest son bought my youngest the tickets for his birthday and when he opened it...he stared in unbelief and started sobbing saying, "this is a once in a life experience" he loves Valentino Rossi :) We will get some pictures for you :)
