CafeRacer650 said:
I hope we will get to meet you, your son, and your bike at Barber this year!!!
You won't be dissapointed, they are awesome. Zeke's passion is through the roof as is his father's support. you can't beat that combo,truly inspiring and I am honored to be mentioned in the vid!!
Luugo86 said:
95 mains are not stock for a cb200.. 88s are. I was having very similar problems with my 200 because I didnt know that the PO rebuilt the carbs with larger jets in every circuit than stock requirements ask for. I would just return the carb configuration to the stock settings:
- 88mains
-38 slow/pilot jets
- needle clip in middle or 3rd position
Then go by the manual and sync the throttle cap screws, and set the idle and air mixture screws. If you do all that and still have problems than you will know it isnt a fuel delivery problem in the carbs.
This is just my 2cents from experience, there are many fellas on here with much more wisdom than I. Best of luck brother. 8)
Sorry to hijack the thread ;)
i ported the head, installed heavier valve-springs and milled the head. Also running pods. So i guess returning to stock is no option for me. Also, last night i ran her for a while and decided to take of the pods ( i know, gravel, small rocks, children bla bla)and she ran WAY better. Plugs were a bit blackish before aswell so my guess is she's getting to much gas. By removing the pods i levelled it out a bit. But then i dont understand why she bogs on 4/5 and up. She will do 85km/h without pods on it. I'm confused but will get some 102,5 jets and see.
no problem Bert! Lucky is running great on 102.5's... Bronze plugs starts no problem after running her through a breakin. We have Uni filters only for the country ... Cause we have small children, sheep, and deer. Get rid of the pods... Unless you can use the tube that connects to airbox. I have read numerous strings with cb's having turbulence problems with pods direct mounted to the carbs. Also we measured our float height from just below the gasket instead of the body as the book said at a wise old foxes recommendation.
We have some velocity stacks we are saving for the track but for now we have Valentino Grassy running the Circuit de Bermuda in the backyard and don't want Lucky to suck in a rascally rabbit.
WHAHAHAHA!
I know, the pods suck. Stock airboxes had to go and no filter is a no-go. Velocity's is a no-go in the city aswell, so my options are kinda limited to pods. i'll get some bigger jets and report my findings.
What do you mean with ' measured float height at the gasket'? i measured mine at the base of the carb, where the gasket is touching the carb body. There's a little material left out on one side to put a ruler in. If i did it incorrect, please teach me. Do i have to set the float needle higher or lower?
teazer said:
I'd show you the dyno charts and porting specs but then I'd have to kill you :-)
I corrected the missing/broken links.
[end threadjack]
thanks Teazer we had to do some snap shots from one of your videos to get a picture but went through your string. Love the tailights! We need to light Lucky up and have been waiting to find the right combo...I think we may have found it! Love your Phat Tracka! Big bodacious curvy roads are wayyy more fun to ride than a skinny straight road that leaves you with a blank stare and takes all your possessions locks your dog up in the bathroom tries to take the motor off your boat...oh sorry I digressed...that was thirty years ago. Why are skinny blondes bitchy? .....they are hungry :) I tell Zeke women are like carbs if they run too lean they will blow stuff up and then you have to rebuild...and if the sun comes out or the elevation changes or you buy motorcycle parts you may need to rejet :)
Bert Jan said:
WHAHAHAHA!
Bert you are funny yea me teach u lol. That is a 1st grader teaching Van Gogh how to paint. Yea that is the way we did it. Grab a pair of these Uni's. heb je gecompenseerd voor het zijn onder de zeespiegel....:)
Tim said:
Don't forget to oil those bad boys :)
and it is little observations like that...that keep a noobs new engine from being damaged...we got a little anxious and forgot to oil. Thanks!
hehe ,well i'm no where near van gogh, and you're no where near 1st grader. Besides, this places teaches us all. Live and learn ;)
After the 3 run of Sonreirs tutorial and breaking in an engine Lucky is @ 135 psi on both cylinders and a big shout out to Tim... Our Uni's are oiled.
Awesome Project and cool way of doing it. My son at age 11 restored his first motorcycle. 1972 Suzuki TS 185 Sierra. He then Restored his 1974 GT250 Hustler at age 12. Now that his dad is now somewhat disabled he does most of the labor on my build at age 14.
His Sierra.
The Hustler
Keep up the great work. Spending the time now with your kids will make them better parents and adults.
His Sierra.
The Hustler
those bikes are beautiful!!!!Tell your son he did a great job!!!
He knows. Lol. His 185 got people's choice over my ELR at a show. Haven't heard the end of it.
