filled battery with distilled and....
jackditch
Active Member
Lets start by saying the bike was running fine prior. Had a dimming headlight/signal issue so i checked the battery for maintenance and the levels were low. i filled each chamber with store bought distilled water between the lines and capped it. tried to start, nothing. charged overnight with trickle, nothing again. it be worth noting that i cannot recall whether i connected +/- first (not sure if that impacts, had read somewhere that it may). all connections +/- are correct at the moment. battery is less than 2 years old, free of corrosion etc. ??
Generally speaking, you fill a discharged battery ONLY to the bottom line. When it is fully charged it will go up slightly. If you fill higher than that, you will most likely dilute the solution too much and cause a failure for your battery. The battery may also have a dead cell in it. Or your electrical system has a failure somewhere and that beat the battery up over the last couple of years. Many things to consider, but easiest is to bring it in to a battery store and have them check it.
The reason for disconnecting the ground first, and reconnecting it last is so that when you are connecting/disconnecting the positive terminal, if your tool happens to touch the frame, you won't get a big fiery spark.
After charging the battery, check it's voltage. It should be somewhere around 12.8 volts or higher after charge. Take it to an auto parts store. They will load test it for you.
You may have ruined the battery. The plates can shed bits of material when you let it run dry, and that shorts out the cells.
ADC, it was just slightly below the lower level line on 3 chambers. prob worth mentioning that for some rookie reason, i gave er a little shake to mix it up. not advised?
Assuming I had no ignition/electrical response whatsoever after charging, is it safe to say the battery is toast?
Thanks MBBruno
I will get it tested regardless.
That doesn't sound too bad. It wasn't that low. I sometimes tilt a battery back and forth a bit to mix the new water with the electrolyte.
You will know more after you test the battery. The battery may not be the reason your bike is having a problem.
I agree, it could be something else. Did you check all of your fuses? I guess we didn't ask if the lights lit up or anything. And can I assume its the scrambler we are talking about? Try kicking it over to see if you have spark?
yeah, the scrambler.....havent checked fuses. the head/tail lights were dimming when my left signal flashed. bike started up just fine every time prior to battery decision. figured i'd top up the cells to see if it that helped. now i'm searching for answers. unfortunately kick spring is broke, so that isnt an option right now.
The charging systems were marginal at best on those old gals. If the headlight etc was dimming when your blinkers were on, you may have some corrosion to trace down in that circuit, or some charging issues. I'd get the battery tested first and go from there. They will tell you right away whether the battery is toast. Good luck sir.
