FINE. I need some help. '72 cb350f
Thrasher
Bike should start but the wiring on it is boggling my mind, I made the whole wiring harness from scratch and have everything done up front on the bike. I could really use a fresh mind on it because i need this bike running! Have a couple wiring diagrams and plenty of tools. Bikes ready to crank over and start on tuning the carbs once this is done. Hit me up and help me get this thing running, its so close its driving me insane! build thread in the signature, here's a pic for ya anyway!
This is the wiring diagram i've been going off of
http://oldmanhonda.com/MC/wiring350F.html
On the starter solenoid i have 2 wires coming from the positive side,
1 goes to the rectifier
2 goes to the main fuse then to the ignition
the yellow and red wire go to the starter button and theres also a black wiring coming out with that that i can't figure out what its for. So one question is whats it for/do i need it?
Second question is the power wire from the battery to the rectifier shows it connecting with a ground, is this right? Why is it like that? To charge the battery with extra power? Just doesn't look right idk.
Any help would be awesome, I might post this in the electrical section as well for those that aren't near me!
Thanks for any info or help!
Chris
That black wire from the starter solenoid is probably the ground wire (or the positive "signal" wire from the starter button). The R/R needs to be grounded as well. Keep hanging in there man, and don't connect a battery until you KNOW you have it all wired up correctly.
Starter button grounds on the bars. The red/yellow comes from the starter button, goes thru the solenoid and turns into black. Black is switched hot on hondas. Red is always hot, black is hot when ignition is on. You need to attach the black wire from the starter solenoid to a black wire in your loom. That way, the solenoid gets power when the button is pushed. The big wires coming from the solenoid (i do not mean the red/yellow and black but the 3 big wires) are usually the main red wire in the loom (going to lock, rectifier and such) and the other red wire goes to battery. The solenoid is designed in such a way that it can switch a high current by using a little. the other high current m6 bolt on the solenoid goes to your starter motor. I strongly suggest using the right color wires. I see red/white turns blue. Dont do that. You might remember it now, but you won't over 2 months. My rule with electrics is; do it right or stay the fuck away from it.
i do not understand the following:
please rephrase.
If you want it to run, just hook up the battery positive to the black/white wires from the coils and kick er to life.
Thankyou so much for the help, I knew it was something obvious. I'm always learning I appreciate the advice!
Heres what confused me on the rectifier, the ground coming into the power for the rectifier.
The red/white is passing underneath, actually, not hooking to the ground. That ground connector is hooking the lights together.
ooohh... (slowly backs into shadowy corner)
Lol all sorted now thankyou! Video will be up on the build thread once the carbs are dialed in hopefully in the next day or two!
jup he's ^^ right. Crossing wires are only connected when intersection is a dot in the same color as both wires. Now come out of that dark corner and ride the sucker ;) Glad we could help!
Purring like a kitten that needs its carbs tuned haha, thanks again guys!
http://www.youtube.com/watch?v=TM9dEC1oDIw
