First Build KZ1000p
MikeMoe
Just started my first build on a kz1000. I'm still new to any custom work on motorcycles, new to cafes, new to the site, but I'm having a blast so far. I bought the bike in California. It was part of the Pasadena PD once upon a time, now its in Arkansas and getting a whole new look.
alot of working has been going into cleaning up the wiring (after taking of all the lights and sirens off) but right now I'm working on the seat. Fiberglass is hell to work with but i think its turning out pretty good.
Welcome!!
Looks like you have made some really good progress. I would have left the sirens on ;D
If you haven't found it already kz400.com has some great forums.
Keep the updates coming.
Getting the seat squared up. I still need to cut off all the tabs and extra brackets on the bike to get a good fit. I'm a little undecided on the carbs. I want to get rid off the stock air box but everything I can find online is telling me pods are a real pain with CV carbs. Has anyone ever tried putting a an exposed air filter on a modified air box? Should get some preformance as well as a more consistant air flow that pods don't offer right? Or should I just try and get slide carbs?
Slides are definitely easier to tune for pods and what not. CV's are not impossible though and there are a few guys that have done it over on kzrider.com
I've seen where some have build a replacement air box from sections of PVC pipe joined to each carb with rubber plumbing connectors and running a single K&N. One example using a 4-cylinder Yamaha here: http://www.xjbikes.com/Forums/viewtopic/t=23710/
Problem is that CV carbs need a constant velocity of air supplied to them; the pods directly connected to the carb throats do not do this. Some have created pod "extensions" (similar to velocity stacks but just straight) to provide a more constant flow but it takes up a lot of space within the frame. It might be easier to get a set of older slide carbs that fit the KZ1000 engine (if you can find them) than get pods to work well with the CV carbs.
sorry for the inactivity over the last month.. my boat and broke dick lawnmower started using up all my project funds so the bike had to take a back seat for a little while. Worthy causes right? :-\
anyways back to the bike. I finally put something onto the bike vs off.... progress! wheels and a couple other small parts are getting powder coated with a gloss black right now. I got a lot of parts in this week so things should start flowing.
still not done with the seat. got the bondo and sand done then well... bondo and sand and bondo and sand again but im happy with it now! I got a layer of primer down but it showed some more defect so just a little more work and the seat should be done. I am planning on using the magma red from my old 05 ninja. I love the color and it brings a little flavor from my first bike on the streets but the only place I can find it is colorrite.com and they want an absurd amount of money for it. I think I'm going to try and mix some paint and get it as close as I can myself.
I really like the shape of your seat - but it looks like it doesn't match up with your tank. How do those butt up with one another?
Did you get a new chain and sprockets? Fork seals? Swingarm bearings?
Brake pads? Steering stem bearings? Oil and filter? Tires? That engine
puts out 100 h.p. and if those items are not addressed it's your neck. I see
it all the time, people gussy up an old motorcycle with this and that and
nothing is done to see if it is mechanically up to snuff. That might work
half assed on a small twin but your bike is capable of 120+. As for any
mechanical questions check out KZRider.com . For your carbs, vm26
and vm28s were stock for that KZ1000s up until '80. Just change carb boots
which probably need to be replaced anyway, with the proper one for the
carbs you choose. CV carbs can be made to work with pods, use only K&N
or Uni, all others are junkand not worth the postage, there are jet
kits available. As for the air box, I left mine on some of my bikes.
On my '79 KZ1000st it has a big circular hole in the back from the factory
for the other pieces to attach to, they are removed with a K&N filter installed.
It would be an option to leave the air box and stay close to the factory
jetting until you have everything else sorted out.
Thanks! I totally winged it. The fit....not the best right now but I'm confident it will shape up. the picture doesn't do it justice. The seat was just sitting on the frame. I plan on drilling the holes and getting an official test fit. pics to come!
I appreciate all the questions! I was planning on using the same chain and sprocket. Everything seems in order to me, i checked chain and everything moves freely and nothing is visibly damaged. brake pads are still good and oil, filter, and tires are all new. I will look into the steering and swing arm bearings.
I disagree on the chain. When a chain kinks it is worn out because it's stretched.
If a sprocket or chain needs to be replaced you replace all three at the same time.
Because the counter sprocket, chain and rear sprocket wear as a matched set.
Replacing just one will prematurely wear out all three. Just trying to save you from
some grief on down the road.
Good to know I'm always open to advice. Like I said at the start I'm pretty new to all this. I'll look into a new chain and sprockets. Thanks!
