First Cafe project (CB450)
Some day sir. I'm very glad I saved up $7 or 800 for mine (can't remember what it was now). WELL WORTH IT. But if you need little things done here and there, there's tons of shops that will do it. Most muffler shop guys are cool and very reasonably priced.
Yeah I had my welding done by a friend, but it's definitely on the tools list for the garage. One day. I'd love to learn how to weld.
Blaahh I can't get the master cylinder to pump the piston out of the caliper. I tried bleeding it too, but I guess bleeding a motorcycle brake is not the same as a car? ??? It pumps air out, but when I tighten the bleeder screw, the lever just pushes in normally with no pressure.
If you guys have any suggestions please let me know. I have a frozen caliper that I soaked the inside with PB Blaster for a week or so, and I want to push it out by pumping some brake fluid into it. Any ideas?
Thanks.
Use an air compressor. Just dont have anything in the way of the piston and get ready for a decent noise. Stick the compressor end in to the bleeder and hit the air. Should shoot across te garage!
I had the same problem with a caliper. I slid a roofing nail in the metal brake line and snugged it up. Then opened the bleeder slightly and put my grease gun on the bleeder screw. Pump grease into the caliper with the grease gun. Piston will pump out nice and easy
I've heard about the compressor one. I'll probably give that a try since I have compressor at work.
Do you guys think the reason it's not pumping any fluid is because of some leak somewhere? I'm using a brand new ebay master cylinder and a slingshot SS braided brake line.
I second the compressor solution. I had this same problem and I took the caliper into a porsche shop above my work and the dude there had it out using this method in 15 minutes.
He had to use a torch on the caliper a little bit. If you use a torch just go gently because you don't want to overheat and warp the aluminum caliper.
Good luck!!
Did you bleed it at EVERY banjo bolt? Very specifically the one that comes right out of the master? Usually there is some air trapped up in there and you will bleed air for DAYS if that isn't bled right. Ask me how I know that. ::)
There's only one banjo bolt since it is a single line. But no I did not. How would I go about that? Just loosen it up, pump fluid out, hold the lever down and tighten the bolt?
Thanks.
Did it come with just a single line when you bought it? Stock they came to a block that contained the stop switch which bolted on the lower triple clamp. You should have 3 banjo bolts, one at the master, one on the input side of the stop switch and a third on the output side of the stop switch
Greg,
This is an aftermarket one I purchased from SlingShot. I purchased a single one to eliminate the brake switch since my master cylinder already has one.
You do it exactly like the bottom bleeder. Pump a bunch, hold the lever down, loosen up the 12mm bolt (guessing its that size?) while still holding the lever. Hear air come out or see fluid come out, and tighten it back up. Then pump a bunch of times and repeat until JUST fluid comes out past those two copper/brass washer you better have on both sides! haha.
It's been a while since I've done any work on the bike. I got a new puppy so he's been taking up all of my time. But I was able to do some things recently.
Got the cylinders bored over 1mm. Painted the lower case and the head. And put the crank and tranny back together.
New valves and sprocket.
