First Cafe project (CB450)
I can't remember (and too lazy to look back through all the pages :P) but are you using stock jets or? Because you have a completely open exhaust, and no air filters....you would have to be about 5 sizes up on the main and AT LEAST one size up on the pilots/idle jets for it to not be lean. When you open the throttle, the extra air makes it too lean for it to keep running and "cuts out". Keep up the good work, this thing is looking great!
I just spent the last half hour viewing this build thread. I have to say I really admire your patience man. you have a real dedication to this project and I think that when it is said and done the bike will be priceless....at least to you.
Alec,
I do not have the rubbers, but I won't be using the factory 450 mounting points because they don't line up. I'm going to have to drill and tap mounting holes.
Bruno,
I have 150 main jets (145 stock). I am planning on buying pods, just haven't gotten a chance yet. I just wanted to start the bike up to make sure it does start up. And I will get some pilot gets if I can find some. Not sure where to get them from. I am also planning on adding either mufflers or custom exhaust with baffles.
Thanks for the tip though!
Thank you! Really means alot. And I agree, I tested my own patience with this build. But all I want now is for it to be done. But I keep getting busy with other stuff so it keeps getting pushed back.
155 before the start up. I'll test it again after running it for a bit to seat the rings.
She definitely won't run at all with those jettings. Way too much air, not enough fuel! The fact that it fires up at all means you did something right! See if anyone else has done something similar, and get yourself some pods while you search, and exhaust baffles or something to give you a little backpressure from those exhausts. And remember, its always better to run a little rich or even way rich compared to too lean. 8)
Oh, and I forgot to add, if you were at 145 mains (stock), you might want to start with 157.5 (hoping to be dead on, or just slightly rich at this jetting) and there's a few places that sell jets. And if you can't get it to idle nicely, or the idle has to be super high or it dies, you need to shim your needles or move the clip a couple of notches.
DennisKirk in MN has made their jet selection quite a bit larger since I last looked. And I don't know from personal experience but theres a place called jets R US or something similar that people talk about too. May be a good place to look for pilots there if you can't find them locally or at DK.
Thanks for the tip. I've ordered stuff from DK before. I'll check on there to see if they have the jet. Are most CV jets usually universal or do they go by make and model?
So I put the factory filters on, and started her up. It starts up pretty quickly pretty often, every once in a while it needs a few kicks.
But, here's my issue; seems like the right cylinder is not as powerful as the left, but I think it might be a carb issue.
Below is a video, if you guys can help what it could be. The first clip is shortly after I first fired her up. You can see there isn't much exhaust pressure. Then the second clip seems like it wants to have pressure. And by the last one, I noticed it creates pressure on higher rpms. Soooo, do you guys think it might be a carb issue? I'm thinking possibly the pilot jet? Or maybe my vacuum piston is not as free as I thought it would be? Any help would be appreciated it.
Thanks.
http://www.youtube.com/watch?v=AhG3ZlKcIcQ&feature=plcp
One thing to check immediately when you fire the bike up (after it's sat a bit and gotten cold) put your hands on the exhaust pipes. I found that my KZ550 had 3 hot pipes and one that was stone cold but would "push" air/gas whatever out so it appeared to be working. Then when I gave it gas, ie twisting the throttle, it would actually fire up and warm up. Your air mixture screws are probably off. Did you start them with the stock number of turns out from LIGHTLY seated? Normally you start with the stock setup of turns out, then go in (half turn increments) until it stumbles or changes, and go out until it stumbles or changes and find the midpoint. For you, it is most likely not getting enough fuel from the pilot jet (idle jet). I would see about turning the air/mixture screw the appropriate way to make that jet more rich, and I think you'll find that to fix what's happening.
Yeah the exhaust definitely gets hot. It has good pressure in high RPM.
I swapped the pilot jets on the carbs, and it was the same result, so I guess it's not the pilot jet. I also messed with the air mixture screw and it didn't really do anything. I'm not sure what else is left. Timing? Just simple tune up on the carbs? Idk, I'm out of ideas, haha.
Just checking, not nitpicking: The airscrew should change a lot of things depending upon the number of turns out. It can make a perfectly tuned bike run like shit. I had a dude come into the shop last week and said the bike just wouldn't idle. I figured it was a carb sync needed. I check that, they are all damn near perfect...scratching head...check air screws...some person had put them at 1 1/2 turns and they should have been at about 3. It was super lean and not firing on 1 or 2 cylinders at idle. He drove home and wrote me a nice email on how well the bike rode...simple air screw adjustment! haha.
Anyways. Stock setting is 1-1.5 turns out from seated. I read a post where someone said the more turns OUT you go, makes it more RICH. So try starting both of them near 2.5 Turns out and see if that helps anything.
I believe I have the air mix screw at 1 1/2 turn now. I took it out to 3 i believe and it didn't do anything noticeable. When I twist the throttle, it'll stay at high rpm for a few seconds and then drop. I don't have a tach, but if I was to guess i'd say around 3k or so. Also the only way it'll stay on is if it's at a higher than normal rpm. Regular rpm it'll stall out, which I'm guessing should be fixed after a tune up.
I'll mess with it more when I get some free time later this week.
I did a compression test after the build and before the start up, which were both at 155. I haven't done one yet after the start up.
