First Cafe project (CB450)
the fact that it wants to hold rpm leads me to believe that it could be leaking air from the intake manifolds? check that there are no cracks or leaks there as that can certainly cause that very issue.
Thank you! And yeah I wouldn't doubt that they aren't I had the carbs disassembled into pieces for clean up. New throttle cable and everything, So I'm sure I need to resync them. I'm going to try to finish up the seat and tank and get it on the road, then I'll start tuning up the engine and carbs. I have a feeling I'm going to have to mess with the timing/points as well.
Are you referring to the black rubber pieces the carbs bolt on to? Not sure if those are referred as the manifolds or the actual mounting points on the head.
Great read and build, though at the end I was expecting the finished product! Was it ever finished?!?! (Bumping old thread up!)
