Alright thanks guys. Also, I got the bike with two batteries, one a gel and one a traditional lead/acid. I rode the bike around last night for maybe a half hour, then went to ride it a couple hours later and it died after three blocks... I couldn't get it to start with the kick start and the headlight was pretty dim, so I pushed it home and switched out the batteries, and it started right up. I took it out today a couple times, starting it only with the kick every time and rode fine for a ways until I started it again to ride home and it died again at an intersection.... I got it to start with the kick and got a block before it died again, the headlight going dim again. The only way I got it home was to keep it in first gear with high revs. Any ideas on what's wrong? The guy I bought it from said he had the electrical system checked over by a mechanic, with a new rectifier installed, as well as the carbs cleaned and synched. I have all the documentation for this so I know it's not BS but what would it be? If it were an electrical issue why wouldn't it start by kick starting? But if it were a mechanical problem, what would cause it to go from running fine all day to cutting out at low revs suddenly while riding? Any help is much appreciated! It's starting to look like I might be starting my build a bit sooner than planned ;D
